> Taller final drive ratio available?
Mid_Engine_914
post Dec 30 2006, 05:16 PM
I was looking through the PET catalogs for the early 911/912s and later 911s and saw that there is a ring gear and pinion shaft listed with a ratio of 7:27 or 3.857:1 which is taller than the 914's stock 7:31 (4.429:1) ratio. Will this ring gear and pinion shaft work in the 914's 901 tranny?
Mid_Engine_914
post Dec 30 2006, 09:40 PM
You may be right but the information on Renegade's site seems to say that the 901 is fine for motors up to 300 hp (mine would have at most 280) as long as you're not constantly thrashing it. I'm going to gamble that the tranny will be fine with 1500 rpm launches and normal shifting.
(IMG:http://img220.imageshack.us/img220/1413/renegadetrannyinfovy4.jpg)
Mid_Engine_914   Taller final drive ratio available?   Dec 30 2006, 05:16 PM
Crazyhippy   i know 8:31 has been done, not sure what trans it...   Dec 30 2006, 05:30 PM
Mid_Engine_914   I'm hoping to put a VR6 in my car this year an...   Dec 30 2006, 06:22 PM
Crazyhippy   and the 1st time you try to duplicate those #...   Dec 30 2006, 07:01 PM
Mid_Engine_914   Those acceleration numbers were based on a 4000 rp...   Dec 30 2006, 08:28 PM
Mueller   that makes me laugh and wonder after how many mi...   Dec 30 2006, 08:49 PM
Crazyhippy   4000rpm launch on sticky street tires... Thanks f...   Dec 30 2006, 08:41 PM
Mid_Engine_914   So I guess you don't recommend that people use...   Dec 30 2006, 08:50 PM
Mueller   So I guess you don't recommend that people us...   Dec 30 2006, 08:55 PM
scott thacher   So I guess you don't recommend that people u...   Dec 30 2006, 08:58 PM
Mueller   [quote name='Mueller' post='840263' date='Dec 30 ...   Dec 30 2006, 09:04 PM
Crazyhippy   depends on the appliction, ther are NO 2 v-8 cars ...   Dec 30 2006, 09:00 PM
Mid_Engine_914   No problem, I changed it to a 1500 rpm launch (eve...   Dec 30 2006, 09:00 PM
Crazyhippy   i'm traction limited :D Also have another tra...   Dec 30 2006, 09:10 PM
Mid_Engine_914   I just changed it back to an open diff. (no posi) ...   Dec 30 2006, 09:12 PM
Crazyhippy   You have a few People that have done this before w...   Dec 30 2006, 09:14 PM
Mid_Engine_914   You may be right but the information on Renegade...   Dec 30 2006, 09:40 PM
jmmotorsports   I bought a 911 sportomatic transmission a couple m...   Dec 31 2006, 08:48 AM
Mid_Engine_914   I bought a 911 sportomatic transmission a couple ...   Jan 5 2007, 10:45 AM
jmmotorsports   Jerry, so the 7:27 ring and pinion is a bolt-in re...   Jan 5 2007, 09:19 PM
topatrout914   My first 914 was a 1970 with D-jet and I sheared t...   Jan 5 2007, 11:22 AM
brant   YES... The ring and pinion gearing can be changed ...   Jan 5 2007, 12:52 PM
Mid_Engine_914   I appreciate the feedback. The turbo kit is just a...   Jan 5 2007, 10:42 PM
- Lo-Fi Version Time is now: 22nd August 2025 - 06:00 PM
