| jsteele22 |
Dec 31 2006, 03:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Last night I finally got around to using the "Chicago Electric" powdercoating setup I bought at HF a couple of months ago. It was on sale, like $60, and others have reported satisfactory results with it. I had some problems, though, and wondered if anyone has any ideas to help.
The problem was that the powder delivery was very erratic. Whenever I pulled the trigger or jiggled the gun the tiniest bit, a huge blast of powder would come out. Huge. I'd say, 1/16" or so of powder would splat out onto the work. After the huge splurt, the powder would come out in a reasonable manner, and go right where it was supposed to. Gradually, though, the fog would get thinner and thinner, and I'd have to shake the gun a tiny bit. This produced another huge splurt, then another interval of acceptable flow. To get by, I had a scrap metal shield that I kept in front of the work until the splurt was over, then moved out of the way during the intervals of acceptable operation. It works, but it's tedious and messy. The instructions say to either use 10-15 psi regulated at the compressor, or to use the regulator screw on the gun itself. I'm using the shop at my work, and the compressor is off in a different room that I don't have a key for. So I bought a cheapo HF regulator that I screwed onto the gun, and before loading it with power, tried to test the operation. With the trigger pulled, I could - barely - regulate the pressure, but as soon as I released the trigger, the pressure would climb to line pressure. The POS Chinese regulator wasn't regulating. Then, based on the instructions, I removed the regulator and tried regulating the air with the screw built into the gun. No way of knowing the pressure, but from the sound I could hear the rate of flow and trim it to something reasonable. In any case, the air flow is smooth and steady. Any tips or suggestions ? The obvious thing to try is buy a non-crap regualtor. But has anyone had luck using the metering screw in the gun itself ? My hunch right now is that maybe I had the air flow too slow. How rapidly should the powder coat the work ? TIA, Jeff p.s. I'm off skiing tomorrow; won't be back until Tues. |
| jsteele22 |
Jan 2 2007, 03:06 PM
Thanks for all the info. The glossy area I mentioned was definitely at a lower temperature while curing; it was at the bottom while the part was hangining, and the radiant heat from the propane heater wasn't as intense down there. The second part (the pan itself) was much more even, 'cause I paid a lot more attention to keeping the heat even. My heat setup was pretty half-assed, just a radiant propane heater and some aluminum plates as reflectors. I noticed that the dark steel plate below the parts (welding table top) actually got much warmer than the aluminum. (Higher emissivity, lower conductivity.) So steel plate "reflectors" (i.e., that absorb and re-emit heat) would probably make a much more uniform oven set up. Also, thanks for the MEK rub test idea. |
jsteele22 First powder coating, results so/so Dec 31 2006, 03:41 PM
scotty b Jeff if you didn't do it the first thing to do... Dec 31 2006, 04:26 PM
jsteele22 B)-->
Lawrence Scott is right about shaking the powder.
The powd... Dec 31 2006, 05:55 PM
jsteele22
The pow... Dec 31 2006, 06:11 PM
seanery :ttiwwp: Dec 31 2006, 06:16 PM
jsteele22
:ttiwwp:
Pics of the finished job, or pics of ... Dec 31 2006, 07:34 PM
John More than likely you didn't get a full cure on... Jan 1 2007, 01:09 AM
scotty b
To cure parts like that pan, I would shoot for ... Jan 1 2007, 04:35 PM
PRS914-6 Make sure you have an air regulator on the gun. I... Jan 1 2007, 01:22 AM
Gint :agree:
If your propblem is powder delivery than y... Jan 1 2007, 12:43 PM
736conver Moisture can really cause some erratic problems. ... Jan 1 2007, 01:07 PM
Gint :agree: in theory with a caveat. RTFM, or read t... Jan 1 2007, 07:29 PM
John
Sorry to burst your bubble, but you can definate... Jan 1 2007, 09:06 PM
pankopp is the powder universal to all guns. for example ... Jan 1 2007, 09:16 PM
John Powder can typically be used in any application eq... Jan 1 2007, 09:28 PM
scotty b John part of my job is powder coating, both commer... Jan 2 2007, 05:47 PM
John Yes we sell Batch Ovens as well as automated ovens... Jan 2 2007, 10:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 12:08 AM |
