> Look y'all, I done welded iyut., My first try...
SGB
post Jan 2 2007, 05:41 PM
just visiting
OK. It looks AWFUL. JUST AWFUL. But thes pieces are really and fully attached. Even actually fused like real welding in a few spots. I'm gonna keep practicing a little before I attempt car stuff, I think. (IMG:style_emoticons/default/smile.gif)
For a cheapie HF wire feed (not mig), it seems to work OK. Who has some good welding tips? I saw something on the almighty internet that indicated there might be primer of some kind? When do ya use this? What do I need to look out for? It's kinda fun. The biggest challenge is starting "in the dark". How easy is it to burn 914 sheet metal up? This is only a two setting unit- high or low. So far I've been using just low.
So here is my sculpture.
Now I really need a good cut-off tool....
JPB
post Jan 2 2007, 06:35 PM
The Crimson Rocket smiles in your general direction.
Its flux core wire right? For mild steel I think E71T1 is the one to use for flux core .035 in dia.
If you want to learn how to weld, get two plates and but them together flat. Allow for a 1/8" gap between the two plates you will be welding. Fasten them down at the top and bottom with clamps or even a weld tack. The trick is to bridge the gap and burn completely through the metal which should be about 1/8" thick. You need to run just enough heat as to not burn through but still need to weave back and forth from one side to the other and filling the gap with weld wire. When welding, you should see a small puddle of moulten metal which you need to keep wet and stretch it from one end of the plates to the end. If done correctly, it will look like flowing water, about 1/4" wide and slightly convex to almost flat. Just do little even circles in the moulten puddle and it will be perfect. The wire should not bounce as you are doing this but melt smoothly so keep your wire speed in ballance with the heat setting you use. (IMG:style_emoticons/default/biggrin.gif)
SGB   Look y'all, I done welded iyut.   Jan 2 2007, 05:41 PM
McMark   It's a start! :D The Harbor Freight auto...   Jan 2 2007, 05:58 PM
Heeltoe914   :agree: It's a start! :D The Harbor F...   Jan 2 2007, 06:22 PM
JPB   Its flux core wire right? For mild steel I think ...   Jan 2 2007, 06:35 PM
SGB   Thanks folks. The auto darkening helmet sounds li...   Jan 2 2007, 08:10 PM
Vacca Rabite   So far all of the welding that I have done on my c...   Jan 2 2007, 08:22 PM
Crazyhippy   yes you can weld upside down, burns are a bitch, b...   Jan 2 2007, 08:30 PM
nebreitling   just my 02: don't go near your car with that ...   Jan 2 2007, 09:14 PM
SGB   use it for mending fence or fixing a plow or som...   Jan 2 2007, 09:22 PM
PRS914-6   If you are going to try to weld body parts with an...   Jan 2 2007, 09:29 PM
alpha434   Get a welding book. It helps to pre-heat the work...   Jan 2 2007, 09:44 PM
andys   And DON'T get a crappy auto-darkening helmet...   Jan 2 2007, 09:57 PM
McMark   And DON'T get a crappy auto-darkening helmet ...   Jan 3 2007, 12:38 AM
Air_Cooled_Nut   ...And DON'T get a crappy auto-darkening helm...   Jan 3 2007, 02:29 PM
Krieger914   The HF helmut is $50. I took a welding class...   Jan 2 2007, 10:21 PM
John   If you are using wire feed (not MIG) then you shou...   Jan 2 2007, 10:39 PM
highways   Either go with a quality auto darkening or a quali...   Jan 3 2007, 01:46 AM
John Kelly   Try welding with no gap. Gaps are for thicker mat...   Jan 3 2007, 06:19 AM
faux916   One should always practice welding on the wifes ca...   Jan 3 2007, 08:22 AM
spunone   If ya can't see for shit when welding ya might...   Jan 3 2007, 02:37 PM
Lawrence   Looks good, dude. Come borrow my welding helmet, ...   Jan 3 2007, 03:03 PM
Lawrence   And by good... I mean for a first try. You may NO...   Jan 3 2007, 03:08 PM
cooltimes   I agree with Rusty. Not bad for a 1st time adventu...   Jan 3 2007, 03:22 PM
SGB   WOW. Great site, Mike. Thanky much.   Jan 4 2007, 08:16 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:15 PM
