| SGB |
Jan 2 2007, 05:41 PM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
OK. It looks AWFUL. JUST AWFUL. But thes pieces are really and fully attached. Even actually fused like real welding in a few spots. I'm gonna keep practicing a little before I attempt car stuff, I think. (IMG:style_emoticons/default/smile.gif)
For a cheapie HF wire feed (not mig), it seems to work OK. Who has some good welding tips? I saw something on the almighty internet that indicated there might be primer of some kind? When do ya use this? What do I need to look out for? It's kinda fun. The biggest challenge is starting "in the dark". How easy is it to burn 914 sheet metal up? This is only a two setting unit- high or low. So far I've been using just low. So here is my sculpture. Now I really need a good cut-off tool.... Attached thumbnail(s)
| VaccaRabite |
Jan 2 2007, 08:22 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
So far all of the welding that I have done on my car has been flux core, as I was too cheap to go out and get a gas bottle for my welder. Welding sheet metal is HARD with flux core. You will burn through it, especially while you are learning.
As I understand it, if you clamp copper to the back of the metal that you are welding, it acts as a heat sink and and really helps burn through. Also, the weld is not supposed to stick to the copper. Of course I learned this after I was done with just about all of my sheet metal welding. Butt welding looks nicer, but is much harder. when ever possible I just cut the patch slightly larger and welded the over lap. That _always_ worked much nicer and gave me a stronger weld the first time. Course, for body work, that might not be possible. Zach |
SGB Look y'all, I done welded iyut. Jan 2 2007, 05:41 PM
McMark It's a start! :D
The Harbor Freight auto... Jan 2 2007, 05:58 PM
Heeltoe914 :agree:
It's a start! :D
The Harbor F... Jan 2 2007, 06:22 PM
JPB Its flux core wire right? For mild steel I think ... Jan 2 2007, 06:35 PM
SGB Thanks folks. The auto darkening helmet sounds li... Jan 2 2007, 08:10 PM
Crazyhippy yes you can weld upside down, burns are a bitch, b... Jan 2 2007, 08:30 PM
nebreitling just my 02: don't go near your car with that ... Jan 2 2007, 09:14 PM
SGB
use it for mending fence or fixing a plow or som... Jan 2 2007, 09:22 PM
PRS914-6 If you are going to try to weld body parts with an... Jan 2 2007, 09:29 PM
alpha434 Get a welding book.
It helps to pre-heat the work... Jan 2 2007, 09:44 PM
andys
And DON'T get a crappy auto-darkening helmet... Jan 2 2007, 09:57 PM
McMark
And DON'T get a crappy auto-darkening helmet ... Jan 3 2007, 12:38 AM
Air_Cooled_Nut
...And DON'T get a crappy auto-darkening helm... Jan 3 2007, 02:29 PM
Krieger914 The HF helmut is $50. I took a welding class... Jan 2 2007, 10:21 PM
John If you are using wire feed (not MIG) then you shou... Jan 2 2007, 10:39 PM
highways Either go with a quality auto darkening or a quali... Jan 3 2007, 01:46 AM
John Kelly Try welding with no gap. Gaps are for thicker mat... Jan 3 2007, 06:19 AM
faux916 One should always practice welding on the wifes ca... Jan 3 2007, 08:22 AM
spunone If ya can't see for shit when welding ya might... Jan 3 2007, 02:37 PM
Lawrence Looks good, dude.
Come borrow my welding helmet, ... Jan 3 2007, 03:03 PM
Lawrence And by good... I mean for a first try. You may NO... Jan 3 2007, 03:08 PM
cooltimes I agree with Rusty. Not bad for a 1st time adventu... Jan 3 2007, 03:22 PM
SGB WOW. Great site, Mike. Thanky much. Jan 4 2007, 08:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:55 PM |
