> First powder coating, results so/so, anybody use the cheapo HF unit ?
jsteele22
post Dec 31 2006, 03:41 PM
Last night I finally got around to using the "Chicago Electric" powdercoating setup I bought at HF a couple of months ago. It was on sale, like $60, and others have reported satisfactory results with it. I had some problems, though, and wondered if anyone has any ideas to help.
The problem was that the powder delivery was very erratic. Whenever I pulled the trigger or jiggled the gun the tiniest bit, a huge blast of powder would come out. Huge. I'd say, 1/16" or so of powder would splat out onto the work. After the huge splurt, the powder would come out in a reasonable manner, and go right where it was supposed to. Gradually, though, the fog would get thinner and thinner, and I'd have to shake the gun a tiny bit. This produced another huge splurt, then another interval of acceptable flow. To get by, I had a scrap metal shield that I kept in front of the work until the splurt was over, then moved out of the way during the intervals of acceptable operation. It works, but it's tedious and messy.
The instructions say to either use 10-15 psi regulated at the compressor, or to use the regulator screw on the gun itself. I'm using the shop at my work, and the compressor is off in a different room that I don't have a key for. So I bought a cheapo HF regulator that I screwed onto the gun, and before loading it with power, tried to test the operation. With the trigger pulled, I could - barely - regulate the pressure, but as soon as I released the trigger, the pressure would climb to line pressure. The POS Chinese regulator wasn't regulating. Then, based on the instructions, I removed the regulator and tried regulating the air with the screw built into the gun. No way of knowing the pressure, but from the sound I could hear the rate of flow and trim it to something reasonable. In any case, the air flow is smooth and steady.
Any tips or suggestions ? The obvious thing to try is buy a non-crap regualtor. But has anyone had luck using the metering screw in the gun itself ? My hunch right now is that maybe I had the air flow too slow. How rapidly should the powder coat the work ?
TIA, Jeff
p.s. I'm off skiing tomorrow; won't be back until Tues.
John
post Jan 2 2007, 10:25 PM
member? what's a member?
Yes we sell Batch Ovens as well as automated ovens. I/R ovens (electric or gas) are definately a viable method of curing out powder.
Some of the testing that we perform at our lab and out in the customers facility is called running a datapaq. A DataPaq is a temperature recorder. Thermocouple probes are placed at different locations of a test part, the part is then placed in the oven (I/R or Convection) for a given amount of time (based on the powder schedule) and then the part is removed.
You can then chart the various temperatures of the probes for the entire time span and watch as they heat up differently. The trick is to get the metal temp up to cure temp for the time required to reach full cure without overheating the powder. Adjustments can be made to an oven (vary the temp in a convection oven, or in the case of IR, one can vary the percentage output of the emitters or in some instances, vary the distance between the part and the emitter).
In the case of home brew powder curing, the best method I have heard of is to obtain an old household oven (the larger and cheaper, the better). The temperature controls are fairly straight forward and can be more easily controlled than I/R space heaters.
You will have to play with emitter output and distance to the part for the I/R space heater thing to work out. I'm sure it can be done, but it would be a lot of work.
The best thing about automated or hand pushed conveyorized powder curing is that the parts are not disturbed much after the application of powder. The powder is fragile until it starts to gel and flow out. Another advantage is that the part never looses being in contact with a good ground.
If you are interested in talking with an application specialist (not me as I am an Engineer), PM me and I'll send you our company contact info.
Back to your regularly scheduled program.
jsteele22   First powder coating, results so/so   Dec 31 2006, 03:41 PM
scotty b   Jeff if you didn't do it the first thing to do...   Dec 31 2006, 04:26 PM
jsteele22   B)-->
- Lo-Fi Version Time is now: 15th April 2026 - 12:06 AM
