jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
pelican says at this link...
http://www.pelicanparts.com/catalog/shopca..._pg3.htm#item12 "Old, worn out original brake lines are not only bad for performance, but are outright dangerous. Replace your worn out factory original lines with high quality replacement lines. Or for better durability and increased stiffness of braking, replace your original lines with stainless steel braided ones. These lines will not expand when pressure is applied because of the outer stainless steel sheath." but at this link they say... http://www.pelicanparts.com/techarticles/9...MW_calipers.htm WARNING: Stainless lines are for "off-road use only" (i.e. for racing), and there have been instances the stainless steel braid can wear through the Teflon lining, some with catastrophic results (i.e. deaths). |
Trevorg7 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region ![]() |
I got my DOT approved set from High Performance House.
T |
Lo-Fi Version | Time is now: 11th July 2025 - 07:11 AM |
