> Re-keying your locks, The how-to thread
markb
post Jan 10 2007, 05:50 PM
914less :(
I was re-keying a lock for someone today, and thought it might be a good time to take some pictures & explain how you can do this yourself. It’s not rocket science, if I can do it, anyone can do it. Please correct me if I’m wrong, or use the wrong terminology.
I’ll start with a door handle, because that seems to be what needs to be re-keyed the most.
Your standard 914 door handle.
hwgunner
post Jan 10 2007, 10:57 PM
914 Parts @ Discount Prices 800.321.5432
Mark, you are the man. I'm still going to pay you to do it when its time though. Remember, I part 'em out for a reason.
markb   Re-keying your locks   Jan 10 2007, 05:50 PM
markb   Remove the screw that holds the tumbler in place. ...   Jan 10 2007, 05:55 PM
markb   Once the tumbler is removed, you can see how the...   Jan 10 2007, 05:58 PM
markb   This might be a good time to discuss the wafers Th...   Jan 10 2007, 06:03 PM
markb   Before you start replacing wafers, wipe the accumu...   Jan 10 2007, 06:11 PM
markb   Since you have the door handle out, you should che...   Jan 10 2007, 06:22 PM
mikez   Good write up....   Jan 10 2007, 06:47 PM
markb   Thanks. My brain hurts now, so I have to wait awhi...   Jan 10 2007, 06:49 PM
cooltimes   Mark, nice lesson. Couple of questions. Are you s...   Jan 10 2007, 07:00 PM
markb   I'm keying a whole set to one key at the momen...   Jan 10 2007, 07:04 PM
Brian_Boss   One additional thought to a great write up. If, af...   Jan 10 2007, 08:39 PM
markb   I just re-read the how-to over on Pelican. You mig...   Jan 10 2007, 08:41 PM
914Sixer   One thing I have noticed over the years, the pins ...   Jan 10 2007, 10:25 PM
markb   One thing I have noticed over the years, the pins...   Jan 10 2007, 10:30 PM
hwgunner   Mark, you are the man. I'm still going to pay...   Jan 10 2007, 10:57 PM
markb   Ok, moving on to the ignition switch. tumbler Ther...   Jan 11 2007, 07:35 PM
markb   At the tip of the punch, you’ll see a pin. There...   Jan 11 2007, 07:40 PM
markb   Now you re-key the tumbler by replacing the wafers...   Jan 11 2007, 07:46 PM
porsche913b_sp   Great Write Up, thanks. I need to get off my but a...   Jan 12 2007, 09:39 AM
Bartlett 914   If you have a glove box or a front trunk lock but ...   Jan 12 2007, 12:48 PM
markb   If you have a glove box or a front trunk lock but...   Jan 13 2007, 01:35 AM
evan   Ok, so now after reading all this, I feel confiden...   Jan 13 2007, 02:11 PM
markb   Re-keying the rear trunk lock is pretty easy, so y...   Jan 13 2007, 03:38 PM
craig downs   Excellent thread. I would like to see this make it...   Jan 13 2007, 03:49 PM
dflesburg   911 ignition switch?   Jan 13 2007, 10:20 PM
markb   I've done an SC switch. Maybe after all the 91...   Jan 13 2007, 10:24 PM
So.Cal.914   Thanks, informative thread.   Jan 14 2007, 12:30 AM
DEC   I love this place.... :wub: Thanks for sharing, v...   Jan 14 2007, 07:41 AM
r_towle   get off your ass and do the rest of the locks...co...   Jan 16 2007, 01:54 PM
markb   Geez, pushy! :D I'm waiting for an ear...   Jan 16 2007, 02:32 PM
Instru-Mental   Thanks Mark! This was an awesome thread. I ex...   Jan 16 2007, 03:25 PM
r_towle   I did one better... This thread inspired me. I we...   Jan 16 2007, 03:31 PM
John   I've been following along this thread and ther...   Jan 16 2007, 04:19 PM
markb   I'm really glad this is making sense, I'm ...   Jan 16 2007, 09:28 PM
markb   The Early Switch Since these are quite a bit diff...   Jan 23 2007, 05:18 PM
markb   Now you can get to the housing. This housing has t...   Jan 23 2007, 05:24 PM
markb   The Later (75-76) Switch On this one, it seems th...   Jan 23 2007, 05:30 PM
markb   Here is the pin that needs to be pushed through. ...   Jan 23 2007, 05:36 PM
markb   Now you have the tumbler apart. Notice the 2 pins...   Jan 23 2007, 05:41 PM
markb   Once the front part is on, put the spring and rear...   Jan 23 2007, 05:46 PM
markb   The Front Trunk Lock I did not have a key for thi...   Jan 23 2007, 05:49 PM
markb   Note the locking pin, it needs go back in the same...   Jan 23 2007, 05:53 PM
dflesburg   okay all my locks are set, except my 911 ignition ...   Jan 23 2007, 07:22 PM
markb   okay all my locks are set, except my 911 ignition...   Jan 23 2007, 07:37 PM
rezron   Great job on the "How to " thread! ...   Jan 26 2007, 10:13 PM
markb   Glad to hear it! This really isn't that ha...   Jan 26 2007, 10:31 PM
jim_hoyland   I finally got my truck and glve box locks done. On...   Feb 17 2007, 05:52 PM
markb   Since the lock cyls are curved, I would think the ...   Feb 17 2007, 07:03 PM
jim_hoyland   Sorry, I wasn't clear. I'm asking whether ...   Feb 17 2007, 09:28 PM
markb   Correct, the doors & ignition switch get all s...   Feb 17 2007, 10:20 PM
PRS914-6   Great thread......I took all my locks down to a lo...   Feb 18 2007, 06:34 PM
jim_hoyland   My guess, having just done this is that if both ke...   Feb 18 2007, 09:44 PM
markb   Moving on to the rear trunk lock. You will need a ...   Feb 21 2007, 01:43 PM
markb   Clean and re-key in the normal fashion. Fit the me...   Feb 21 2007, 01:45 PM
mrhurtalot   i used my cyl. from the trunk lock (got a pull cab...   Feb 21 2007, 02:05 PM
markb   And now for the dreaded glovebox lock. It’s a pa...   Feb 21 2007, 04:22 PM
markb   You will need a pair of snap-ring pliers to remove...   Feb 21 2007, 04:24 PM
jim_hoyland   Mark, Got the hood lock in but having trouble wit...   Feb 21 2007, 08:50 PM
markb   I'm sure the cable can be replaced. I've e...   Feb 21 2007, 09:39 PM
jim_hoyland   That the trick I missed-leaving the sheath in plac...   Feb 21 2007, 09:55 PM
markb   Uh-oh. :( IIRC, it will be easiest to have 2 peo...   Feb 21 2007, 10:10 PM
dyw914   Mark, great thread. I was disassembling my trunk ...   Feb 22 2007, 12:51 PM
markb   Mark, great thread. I was disassembling my trunk...   Feb 22 2007, 02:21 PM
7T Porsha   My handles are good...are the lock cylinders avail...   Feb 22 2007, 01:19 PM
markb   My handles are good...are the lock cylinders avai...   Feb 22 2007, 02:23 PM
914Sixer   The 75-76 steering column requires you to mark and...   Feb 23 2007, 08:54 AM
jim_hoyland   Yup; just learned about this today.Why didthey mak...   Feb 23 2007, 09:36 PM
markb   Jim, were you able to take any pics you could post...   Feb 24 2007, 12:46 AM
bd1308   A dremel makes any key suddenly work. I took the ...   Feb 23 2007, 02:11 PM
markb   I guess it's time for a little update. I final...   Jun 14 2007, 11:22 PM
orange914   not trying to hijack the thread but have a door lo...   Jun 14 2007, 11:43 PM
markb   It sounds like you need to clean & lube everyt...   Jun 14 2007, 11:47 PM
orange914   It sounds like you need to clean & lube every...   Jun 15 2007, 12:23 AM
markb   I bet the edges of the tumbler have rounded off. T...   Jun 15 2007, 12:27 AM
markb   OK, hopefully I can now finish this thread. This i...   Jun 19 2007, 01:15 PM
dflesburg   sweet.   Jun 19 2007, 04:14 PM
dflesburg   oh, and Thank you   Jul 6 2007, 12:16 PM
markb   You're welcome. :)   Jul 6 2007, 04:20 PM
JPB   Cool thread! For the record, you can stick yo...   Jul 6 2007, 06:48 PM
96740   Great thread. Someone over at 914.club gave me a l...   May 12 2008, 09:05 AM
PRS914-6   If you go to a locksmith and order 1 master kit yo...   May 12 2008, 09:26 AM
96740   If you go to a locksmith and order 1 master kit y...   May 12 2008, 01:25 PM
Lavanaut   The keys I bought have a 3-digit code on the tag, ...   Dec 5 2008, 02:08 PM
markb   The tag I have here has 4 numbers. Interesting tha...   Dec 5 2008, 02:13 PM
nicabr   Great information! :trophy: Helped me a lot w...   Mar 24 2011, 07:11 AM
jim_hoyland   Glad this thread is available ! I just had to ...   Sep 3 2016, 06:55 AM
FlacaProductions   I had a new key cut and it seems that it's juu...   Jun 1 2019, 08:43 AM
fiacra   Thank you for this tutorial! All seems clearl...   Jun 1 2019, 11:40 AM
bbrock   Thank you for this tutorial! All seems clear...   Jun 1 2019, 12:03 PM
fiacra   Thanks Brent! Appreciate the info. I just ca...   Jun 1 2019, 01:00 PM
- Lo-Fi Version Time is now: 4th October 2026 - 03:31 PM
