Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
Since I don't have my original engine & the trans I have has been converted to a side shifter, I was thinking of converting my six to a 915 transaxel & would like to know what everyone thinks is the most practical, or the most economical, or the most bullet-proof, etc... Or should I put in some sort of shifter that will notch me up a bit. The car has new shift bushings & it's still sloppy. I suspect I should check the rear mounts as well. Thanks. (IMG:style_emoticons/default/smoke.gif)
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
The 915 swap is NOT cheap.....requires a cable shifter. WEVO makes the best....it's pricey. Not to mention that a 915 box is $800 for a core...then you usually have to go thru it.
The 901/914 trans is cheap and can handle up to 300hp reliably as long as you keep the 1st gear burnouts to a minimum..... |
Lo-Fi Version | Time is now: 14th August 2025 - 05:50 AM |
