Floor pan repair question, To drill the spot welds or not |
Bartlett 914 |
Jan 13 2007, 08:44 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I am in the process of replacing the floor pans. I have the car on a rotissiere. I can drill out the spot welds with my Blair spot weld cutter. This is still a lot of work and my elbow is protesting. What if I were to cut the pans out but leaving the strips of metal where the spot welds are and weld the pans ofer the top. Is this ill advised? My thoughts were to save time and maybe more metal is better. Less chance of weaking the long with welding heat.
Rusty |
Jan 13 2007, 09:22 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
I don't think there would be any structural problems with what you suggest.
Of course, a future owner might raise an eyebrow at the repair. I have a ViceGrip-type tool that's used to create a "step" in sheet metal. You could create a step and lay the pan in snugly. I believe that would help make your welds neater and the area stronger. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:16 AM |
