Floor pan repair question, To drill the spot welds or not |
Bartlett 914 |
Jan 13 2007, 08:44 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I am in the process of replacing the floor pans. I have the car on a rotissiere. I can drill out the spot welds with my Blair spot weld cutter. This is still a lot of work and my elbow is protesting. What if I were to cut the pans out but leaving the strips of metal where the spot welds are and weld the pans ofer the top. Is this ill advised? My thoughts were to save time and maybe more metal is better. Less chance of weaking the long with welding heat.
dr914@autoatlanta.com |
Jan 13 2007, 09:24 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I am in the process of replacing the floor pans. I have the car on a rotissiere. I can drill out the spot welds with my Blair spot weld cutter. This is still a lot of work and my elbow is protesting. What if I were to cut the pans out but leaving the strips of metal where the spot welds are and weld the pans ofer the top. Is this ill advised? My thoughts were to save time and maybe more metal is better. Less chance of weaking the long with welding heat. By all means drill out the spot welds! Obviously at the front pedal cluster you will have to cut it but the ease of installation will make spot weld drilling well worth it. (spot weld the pan back in as well just like the factory or maybe solid weld if racing). |
Lo-Fi Version | Time is now: 1st June 2024 - 10:54 PM |
