> economical 915 swaps?
Johny Blackstain
post Jan 12 2007, 11:44 PM
Since I don't have my original engine & the trans I have has been converted to a side shifter, I was thinking of converting my six to a 915 transaxel & would like to know what everyone thinks is the most practical, or the most economical, or the most bullet-proof, etc... Or should I put in some sort of shifter that will notch me up a bit. The car has new shift bushings & it's still sloppy. I suspect I should check the rear mounts as well. Thanks. (IMG:style_emoticons/default/smoke.gif)
Joe Bob
post Jan 13 2007, 12:58 PM
Well first off....the thread starter was talking about a street ride. SO my comment on the 901 is still valid. 901s are still cheap and plentiful and reliable up to 300hp......
As to the 915s....they also have issues.....on my N/A 3.6 which is performance chipped with headers I put out 280hp. It fractured second gear due to shaft flex. I rebuilt it with the WEVO intermediate plate upgrade (the shaft tie in plate is standard in a 930 box BTW) AND hogged out the bearing race, pressed in a sleeve and fixed the second gear....this was on a 915 that had less than 80K street miles....30 with the 3.6.....
So....my opinion is that a 915 is not the ultimate cure. Now a 930 or G50.....VERY rarely do THOSE break....
Johny Blackstain   economical 915 swaps?   Jan 12 2007, 11:44 PM
mikez   The 915 swap is NOT cheap.....requires a cable shi...   Jan 13 2007, 12:01 AM
soloracer   The 915 swap is NOT cheap.....requires a cable sh...   Jan 13 2007, 01:51 PM
Dr Evil   There is no excuse for a sloppy shifting 901. Do c...   Jan 13 2007, 12:57 AM
drgchapman   Economical 915 swap... :rotfl: Core: ~$100...   Jan 13 2007, 09:55 AM
grantsfo   I had mine done in the shop. ~$10,000 :...   Jan 15 2007, 10:10 PM
John   I respectfully disagree. In our track only 914 ...   Jan 13 2007, 12:24 PM
Dr Evil   John, thanks for stating your findings. It is alwa...   Jan 13 2007, 12:35 PM
kdfoust   John, thanks for stating your findings. It is alw...   Jan 15 2007, 10:01 PM
mikez   Well first off....the thread starter was talking a...   Jan 13 2007, 12:58 PM
Crazyhippy   Now a 930 or G50.....VERY rarely do THOSE break.....   Jan 13 2007, 01:46 PM
rhodyguy   a $10k trans. zoiks. that's a lot of stra...   Jan 13 2007, 01:00 PM
mikez   Or a .75 circlip falls off the back of the reverse...   Jan 13 2007, 01:52 PM
GeorgeRud   915s can be setup with a shift rod assembly, they ...   Jan 13 2007, 04:41 PM
John   I don't have the figures in front of me (but...   Jan 14 2007, 12:40 AM
Johny Blackstain   I don't have the figures in front of me (bu...   Jan 14 2007, 05:27 AM
mikez   link Above is a link to a street 915 second gear ...   Jan 14 2007, 09:01 AM
GeorgeRud   I believe that Dr. 914 has some Vellios parts (at ...   Jan 14 2007, 10:43 AM
BigDBass   I couldn't have put it better myself.   Jan 15 2007, 10:13 PM
Dr Evil   Hey Kevin, Thank sfor putting that up. I knew the ...   Jan 15 2007, 10:26 PM
Johny Blackstain   :dance: I would like to thank all of you for your ...   Jan 16 2007, 04:36 AM
- Lo-Fi Version Time is now: 14th August 2025 - 05:50 AM
