> Re-keying your locks, The how-to thread
markb
post Jan 10 2007, 05:50 PM
914less :(
I was re-keying a lock for someone today, and thought it might be a good time to take some pictures & explain how you can do this yourself. It’s not rocket science, if I can do it, anyone can do it. Please correct me if I’m wrong, or use the wrong terminology.
I’ll start with a door handle, because that seems to be what needs to be re-keyed the most.
Your standard 914 door handle.
markb
post Jan 23 2007, 05:30 PM
914less :(
The Later (75-76) Switch
On this one, it seems the whole dern thing needs to come out of the column.
I didn’t do that, so I’m afraid you’re on your own there.
This is what it looks like off of the column.
Sorry again for the blurry pics, I forgot to set the macro on the camera.
This is where the release is (in that recess)
Once again, turn the key to release the steering wheel lock, and pull the tumbler free.
markb   Re-keying your locks   Jan 10 2007, 05:50 PM
markb   Remove the screw that holds the tumbler in place. ...   Jan 10 2007, 05:55 PM
markb   Once the tumbler is removed, you can see how the...   Jan 10 2007, 05:58 PM
markb   This might be a good time to discuss the wafers Th...   Jan 10 2007, 06:03 PM
markb   Before you start replacing wafers, wipe the accumu...   Jan 10 2007, 06:11 PM
markb   Since you have the door handle out, you should che...   Jan 10 2007, 06:22 PM
mikez   Good write up....   Jan 10 2007, 06:47 PM
markb   Thanks. My brain hurts now, so I have to wait awhi...   Jan 10 2007, 06:49 PM
cooltimes   Mark, nice lesson. Couple of questions. Are you s...   Jan 10 2007, 07:00 PM
markb   I'm keying a whole set to one key at the momen...   Jan 10 2007, 07:04 PM
Brian_Boss   One additional thought to a great write up. If, af...   Jan 10 2007, 08:39 PM
markb   I just re-read the how-to over on Pelican. You mig...   Jan 10 2007, 08:41 PM
914Sixer   One thing I have noticed over the years, the pins ...   Jan 10 2007, 10:25 PM
markb   One thing I have noticed over the years, the pins...   Jan 10 2007, 10:30 PM
hwgunner   Mark, you are the man. I'm still going to pay...   Jan 10 2007, 10:57 PM
markb   Ok, moving on to the ignition switch. tumbler Ther...   Jan 11 2007, 07:35 PM
markb   At the tip of the punch, you’ll see a pin. There...   Jan 11 2007, 07:40 PM
markb   Now you re-key the tumbler by replacing the wafers...   Jan 11 2007, 07:46 PM
porsche913b_sp   Great Write Up, thanks. I need to get off my but a...   Jan 12 2007, 09:39 AM
Bartlett 914   If you have a glove box or a front trunk lock but ...   Jan 12 2007, 12:48 PM
markb   If you have a glove box or a front trunk lock but...   Jan 13 2007, 01:35 AM
evan   Ok, so now after reading all this, I feel confiden...   Jan 13 2007, 02:11 PM
markb   Re-keying the rear trunk lock is pretty easy, so y...   Jan 13 2007, 03:38 PM
craig downs   Excellent thread. I would like to see this make it...   Jan 13 2007, 03:49 PM
dflesburg   911 ignition switch?   Jan 13 2007, 10:20 PM
markb   I've done an SC switch. Maybe after all the 91...   Jan 13 2007, 10:24 PM
So.Cal.914   Thanks, informative thread.   Jan 14 2007, 12:30 AM
DEC   I love this place.... :wub: Thanks for sharing, v...   Jan 14 2007, 07:41 AM
r_towle   get off your ass and do the rest of the locks...co...   Jan 16 2007, 01:54 PM
markb   Geez, pushy! :D I'm waiting for an ear...   Jan 16 2007, 02:32 PM
Instru-Mental   Thanks Mark! This was an awesome thread. I ex...   Jan 16 2007, 03:25 PM
r_towle   I did one better... This thread inspired me. I we...   Jan 16 2007, 03:31 PM
John   I've been following along this thread and ther...   Jan 16 2007, 04:19 PM
markb   I'm really glad this is making sense, I'm ...   Jan 16 2007, 09:28 PM
markb   The Early Switch Since these are quite a bit diff...   Jan 23 2007, 05:18 PM
markb   Now you can get to the housing. This housing has t...   Jan 23 2007, 05:24 PM
markb   The Later (75-76) Switch On this one, it seems th...   Jan 23 2007, 05:30 PM
markb   Here is the pin that needs to be pushed through. ...   Jan 23 2007, 05:36 PM
markb   Now you have the tumbler apart. Notice the 2 pins...   Jan 23 2007, 05:41 PM
markb   Once the front part is on, put the spring and rear...   Jan 23 2007, 05:46 PM
markb   The Front Trunk Lock I did not have a key for thi...   Jan 23 2007, 05:49 PM
markb   Note the locking pin, it needs go back in the same...   Jan 23 2007, 05:53 PM
dflesburg   okay all my locks are set, except my 911 ignition ...   Jan 23 2007, 07:22 PM
markb   okay all my locks are set, except my 911 ignition...   Jan 23 2007, 07:37 PM
rezron   Great job on the "How to " thread! ...   Jan 26 2007, 10:13 PM
markb   Glad to hear it! This really isn't that ha...   Jan 26 2007, 10:31 PM
jim_hoyland   I finally got my truck and glve box locks done. On...   Feb 17 2007, 05:52 PM
markb   Since the lock cyls are curved, I would think the ...   Feb 17 2007, 07:03 PM
jim_hoyland   Sorry, I wasn't clear. I'm asking whether ...   Feb 17 2007, 09:28 PM
markb   Correct, the doors & ignition switch get all s...   Feb 17 2007, 10:20 PM
PRS914-6   Great thread......I took all my locks down to a lo...   Feb 18 2007, 06:34 PM
jim_hoyland   My guess, having just done this is that if both ke...   Feb 18 2007, 09:44 PM
markb   Moving on to the rear trunk lock. You will need a ...   Feb 21 2007, 01:43 PM
markb   Clean and re-key in the normal fashion. Fit the me...   Feb 21 2007, 01:45 PM
mrhurtalot   i used my cyl. from the trunk lock (got a pull cab...   Feb 21 2007, 02:05 PM
markb   And now for the dreaded glovebox lock. It’s a pa...   Feb 21 2007, 04:22 PM
markb   You will need a pair of snap-ring pliers to remove...   Feb 21 2007, 04:24 PM
jim_hoyland   Mark, Got the hood lock in but having trouble wit...   Feb 21 2007, 08:50 PM
markb   I'm sure the cable can be replaced. I've e...   Feb 21 2007, 09:39 PM
jim_hoyland   That the trick I missed-leaving the sheath in plac...   Feb 21 2007, 09:55 PM
markb   Uh-oh. :( IIRC, it will be easiest to have 2 peo...   Feb 21 2007, 10:10 PM
dyw914   Mark, great thread. I was disassembling my trunk ...   Feb 22 2007, 12:51 PM
markb   Mark, great thread. I was disassembling my trunk...   Feb 22 2007, 02:21 PM
7T Porsha   My handles are good...are the lock cylinders avail...   Feb 22 2007, 01:19 PM
markb   My handles are good...are the lock cylinders avai...   Feb 22 2007, 02:23 PM
914Sixer   The 75-76 steering column requires you to mark and...   Feb 23 2007, 08:54 AM
jim_hoyland   Yup; just learned about this today.Why didthey mak...   Feb 23 2007, 09:36 PM
markb   Jim, were you able to take any pics you could post...   Feb 24 2007, 12:46 AM
bd1308   A dremel makes any key suddenly work. I took the ...   Feb 23 2007, 02:11 PM
markb   I guess it's time for a little update. I final...   Jun 14 2007, 11:22 PM
orange914   not trying to hijack the thread but have a door lo...   Jun 14 2007, 11:43 PM
markb   It sounds like you need to clean & lube everyt...   Jun 14 2007, 11:47 PM
orange914   It sounds like you need to clean & lube every...   Jun 15 2007, 12:23 AM
markb   I bet the edges of the tumbler have rounded off. T...   Jun 15 2007, 12:27 AM
markb   OK, hopefully I can now finish this thread. This i...   Jun 19 2007, 01:15 PM
dflesburg   sweet.   Jun 19 2007, 04:14 PM
dflesburg   oh, and Thank you   Jul 6 2007, 12:16 PM
markb   You're welcome. :)   Jul 6 2007, 04:20 PM
JPB   Cool thread! For the record, you can stick yo...   Jul 6 2007, 06:48 PM
96740   Great thread. Someone over at 914.club gave me a l...   May 12 2008, 09:05 AM
PRS914-6   If you go to a locksmith and order 1 master kit yo...   May 12 2008, 09:26 AM
96740   If you go to a locksmith and order 1 master kit y...   May 12 2008, 01:25 PM
Lavanaut   The keys I bought have a 3-digit code on the tag, ...   Dec 5 2008, 02:08 PM
markb   The tag I have here has 4 numbers. Interesting tha...   Dec 5 2008, 02:13 PM
nicabr   Great information! :trophy: Helped me a lot w...   Mar 24 2011, 07:11 AM
jim_hoyland   Glad this thread is available ! I just had to ...   Sep 3 2016, 06:55 AM
FlacaProductions   I had a new key cut and it seems that it's juu...   Jun 1 2019, 08:43 AM
fiacra   Thank you for this tutorial! All seems clearl...   Jun 1 2019, 11:40 AM
bbrock   Thank you for this tutorial! All seems clear...   Jun 1 2019, 12:03 PM
fiacra   Thanks Brent! Appreciate the info. I just ca...   Jun 1 2019, 01:00 PM
- Lo-Fi Version Time is now: 4th October 2026 - 03:32 PM
