| markb |
Jan 10 2007, 05:50 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
I was re-keying a lock for someone today, and thought it might be a good time to take some pictures & explain how you can do this yourself. It’s not rocket science, if I can do it, anyone can do it. Please correct me if I’m wrong, or use the wrong terminology.
I’ll start with a door handle, because that seems to be what needs to be re-keyed the most. ![]() ![]() Your standard 914 door handle. |
| markb |
Jan 23 2007, 05:53 PM
Note the locking pin, it needs go back in the same way it came out.
![]() Re-key in the normal way. ![]() Reassemble, making sure the locking pin is in correctly. ![]() Put it back in the car, and you’re done. This is a very simple, but time consuming lock. |
markb Re-keying your locks Jan 10 2007, 05:50 PM
markb Remove the screw that holds the tumbler in place.
... Jan 10 2007, 05:55 PM
markb
Once the tumbler is removed, you can see how the... Jan 10 2007, 05:58 PM
markb This might be a good time to discuss the wafers
Th... Jan 10 2007, 06:03 PM
markb Before you start replacing wafers, wipe the accumu... Jan 10 2007, 06:11 PM
markb Since you have the door handle out, you should che... Jan 10 2007, 06:22 PM
mikez Good write up.... Jan 10 2007, 06:47 PM
markb Thanks. My brain hurts now, so I have to wait awhi... Jan 10 2007, 06:49 PM
cooltimes Mark, nice lesson. Couple of questions.
Are you s... Jan 10 2007, 07:00 PM
markb I'm keying a whole set to one key at the momen... Jan 10 2007, 07:04 PM
Brian_Boss One additional thought to a great write up. If, af... Jan 10 2007, 08:39 PM
markb I just re-read the how-to over on Pelican. You mig... Jan 10 2007, 08:41 PM
914Sixer One thing I have noticed over the years, the pins ... Jan 10 2007, 10:25 PM
markb
One thing I have noticed over the years, the pins... Jan 10 2007, 10:30 PM
hwgunner Mark, you are the man. I'm still going to pay... Jan 10 2007, 10:57 PM
markb Ok, moving on to the ignition switch. tumbler Ther... Jan 11 2007, 07:35 PM
markb At the tip of the punch, you’ll see a pin. There... Jan 11 2007, 07:40 PM
markb Now you re-key the tumbler by replacing the wafers... Jan 11 2007, 07:46 PM
porsche913b_sp Great Write Up, thanks. I need to get off my but a... Jan 12 2007, 09:39 AM
Bartlett 914 If you have a glove box or a front trunk lock but ... Jan 12 2007, 12:48 PM
markb
If you have a glove box or a front trunk lock but... Jan 13 2007, 01:35 AM
evan Ok, so now after reading all this, I feel confiden... Jan 13 2007, 02:11 PM
markb Re-keying the rear trunk lock is pretty easy, so y... Jan 13 2007, 03:38 PM
craig downs Excellent thread. I would like to see this make it... Jan 13 2007, 03:49 PM
dflesburg 911 ignition switch? Jan 13 2007, 10:20 PM
markb I've done an SC switch. Maybe after all the 91... Jan 13 2007, 10:24 PM
So.Cal.914 Thanks, informative thread. Jan 14 2007, 12:30 AM
DEC I love this place.... :wub:
Thanks for sharing, v... Jan 14 2007, 07:41 AM
r_towle get off your ass and do the rest of the locks...co... Jan 16 2007, 01:54 PM
markb Geez, pushy! :D
I'm waiting for an ear... Jan 16 2007, 02:32 PM
Instru-Mental Thanks Mark!
This was an awesome thread. I ex... Jan 16 2007, 03:25 PM
r_towle I did one better...
This thread inspired me.
I we... Jan 16 2007, 03:31 PM
John I've been following along this thread and ther... Jan 16 2007, 04:19 PM
markb I'm really glad this is making sense, I'm ... Jan 16 2007, 09:28 PM
markb The Early Switch
Since these are quite a bit diff... Jan 23 2007, 05:18 PM
markb Now you can get to the housing. This housing has t... Jan 23 2007, 05:24 PM
markb The Later (75-76) Switch
On this one, it seems th... Jan 23 2007, 05:30 PM
markb Here is the pin that needs to be pushed through.
... Jan 23 2007, 05:36 PM
markb Now you have the tumbler apart.
Notice the 2 pins... Jan 23 2007, 05:41 PM
markb Once the front part is on, put the spring and rear... Jan 23 2007, 05:46 PM
markb The Front Trunk Lock
I did not have a key for thi... Jan 23 2007, 05:49 PM
dflesburg okay all my locks are set, except my 911 ignition ... Jan 23 2007, 07:22 PM
markb
okay all my locks are set, except my 911 ignition... Jan 23 2007, 07:37 PM
rezron Great job on the "How to " thread! ... Jan 26 2007, 10:13 PM
markb Glad to hear it! This really isn't that ha... Jan 26 2007, 10:31 PM
jim_hoyland I finally got my truck and glve box locks done. On... Feb 17 2007, 05:52 PM
markb Since the lock cyls are curved, I would think the ... Feb 17 2007, 07:03 PM
jim_hoyland Sorry, I wasn't clear. I'm asking whether ... Feb 17 2007, 09:28 PM
markb Correct, the doors & ignition switch get all s... Feb 17 2007, 10:20 PM
PRS914-6 Great thread......I took all my locks down to a lo... Feb 18 2007, 06:34 PM
jim_hoyland My guess, having just done this is that if both ke... Feb 18 2007, 09:44 PM
markb Moving on to the rear trunk lock.
You will need a ... Feb 21 2007, 01:43 PM
markb Clean and re-key in the normal fashion.
Fit the me... Feb 21 2007, 01:45 PM
mrhurtalot i used my cyl. from the trunk lock (got a pull cab... Feb 21 2007, 02:05 PM
markb And now for the dreaded glovebox lock.
It’s a pa... Feb 21 2007, 04:22 PM
markb You will need a pair of snap-ring pliers to remove... Feb 21 2007, 04:24 PM
jim_hoyland Mark,
Got the hood lock in but having trouble wit... Feb 21 2007, 08:50 PM
markb I'm sure the cable can be replaced. I've e... Feb 21 2007, 09:39 PM
jim_hoyland That the trick I missed-leaving the sheath in plac... Feb 21 2007, 09:55 PM
markb Uh-oh. :( IIRC, it will be easiest to have 2 peo... Feb 21 2007, 10:10 PM
dyw914 Mark, great thread. I was disassembling my trunk ... Feb 22 2007, 12:51 PM
markb
Mark, great thread. I was disassembling my trunk... Feb 22 2007, 02:21 PM
7T Porsha My handles are good...are the lock cylinders avail... Feb 22 2007, 01:19 PM
markb
My handles are good...are the lock cylinders avai... Feb 22 2007, 02:23 PM
914Sixer The 75-76 steering column requires you to mark and... Feb 23 2007, 08:54 AM
jim_hoyland Yup; just learned about this today.Why didthey mak... Feb 23 2007, 09:36 PM
markb Jim, were you able to take any pics you could post... Feb 24 2007, 12:46 AM
bd1308 A dremel makes any key suddenly work.
I took the ... Feb 23 2007, 02:11 PM
markb I guess it's time for a little update. I final... Jun 14 2007, 11:22 PM
orange914 not trying to hijack the thread but have a door lo... Jun 14 2007, 11:43 PM
markb It sounds like you need to clean & lube everyt... Jun 14 2007, 11:47 PM
orange914
It sounds like you need to clean & lube every... Jun 15 2007, 12:23 AM
markb I bet the edges of the tumbler have rounded off. T... Jun 15 2007, 12:27 AM
markb OK, hopefully I can now finish this thread.
This i... Jun 19 2007, 01:15 PM
dflesburg sweet. Jun 19 2007, 04:14 PM
dflesburg oh, and Thank you Jul 6 2007, 12:16 PM
markb You're welcome. :) Jul 6 2007, 04:20 PM
JPB Cool thread! For the record, you can stick yo... Jul 6 2007, 06:48 PM
96740 Great thread. Someone over at 914.club gave me a l... May 12 2008, 09:05 AM
PRS914-6 If you go to a locksmith and order 1 master kit yo... May 12 2008, 09:26 AM
96740
If you go to a locksmith and order 1 master kit y... May 12 2008, 01:25 PM
Lavanaut The keys I bought have a 3-digit code on the tag, ... Dec 5 2008, 02:08 PM
markb The tag I have here has 4 numbers. Interesting tha... Dec 5 2008, 02:13 PM
nicabr Great information! :trophy: Helped me a lot w... Mar 24 2011, 07:11 AM
jim_hoyland Glad this thread is available ! I just had to ... Sep 3 2016, 06:55 AM
FlacaProductions I had a new key cut and it seems that it's juu... Jun 1 2019, 08:43 AM
fiacra Thank you for this tutorial! All seems clearl... Jun 1 2019, 11:40 AM
bbrock
Thank you for this tutorial! All seems clear... Jun 1 2019, 12:03 PM
fiacra Thanks Brent! Appreciate the info. I just ca... Jun 1 2019, 01:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 03:31 PM |
