> stroking a 4 cyl
ws91420
post Jan 25 2007, 10:49 PM
Yes I have one a Lensley 914
From: Ruther Glen,VA (halfway between sticks and civilization)
Looking to build a 2270. I know I know get a Jake kit.
I'm a bit of a rebel and want to go at it myself.
Stroker crank 78mm what else is needed.
is a longer cylinder need for the stroke
longer rods should I go chevy or type 4 rod journals
thinking about doing larger intake valves on the heads and using 40mm Webers
Jake Raby
post Jan 29 2007, 08:47 AM
Engine Surgeon
Changing ANY component internally will dictate equal changes to be made to all the otyher support components IF you intend to maintain efficiency, power band and overall effectiveness..
Building a 2270 with stock heads WILL net a worthless powerband that makes all it's power at such a low RPM that it will be worthless in a Sports car- it may work great in a Bus.
I have seen 2270 engines with screwed up combos MAKE LESS power than a stock engine.
It is ALL in the combo.
Guess who has over 100 proven combos for a 2270-
- Lo-Fi Version Time is now: 4th June 2025 - 02:52 PM
