| ninepfourteen |
Jan 30 2007, 04:55 PM
Member ![]() ![]() Group: Members Posts: 70 Joined: 19-March 04 From: western, MD Member No.: 1,820 |
Give us a place to start to trouble shoot.
Not sure which flywheel sensor connects where, but doesn't fire hooked either way. We are not even sure of wiring at this point, although all the Bently checks on the DME plug seem right. Thoughts? Thanks. |
| dflesburg |
Jan 30 2007, 08:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Sometimes people get the two black plugs in the set of three (two black, one gray) reversed...
ninepfourteen 3.2 Conversion; No Spark, Help! Jan 30 2007, 04:55 PM
dr914@autoatlanta.com
Not s... Jan 30 2007, 06:09 PM
ninepfourteen Have voltage at the DME plug contacts for both sen... Jan 30 2007, 06:17 PM
ClayPerrine Without the wiring diagram, I can't give you a... Jan 30 2007, 08:32 PM
John Do you have fuel pressure?
Is there voltage at th... Jan 30 2007, 11:28 PM
736conver The fun of trouble shooting a DME 3.2. :beer3:
... Jan 31 2007, 01:30 AM
ninepfourteen DME relay works
have fuel pressure
pump runs, but ... Jan 31 2007, 05:14 AM
John I switched the two leads where the harness plugs t... Jan 31 2007, 11:10 AM
John Another area to check is the 3 gobs of ground wire... Jan 31 2007, 11:14 AM
ninepfourteen It Lives!
Hot wire to #4 DME terminal was con... Jan 31 2007, 11:29 AM
John We still want pics! Jan 31 2007, 12:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 08:58 PM |
