| StratPlayer |
Jan 31 2007, 04:21 PM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,383 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
Been looking at the gaskets that came with the gasket kit I bought. The gaskets for the cyl. and heads total 7,, 3 alum. gaskets thin, 4 smaller but thicker alum. gaskets. Shouldn't the total for these gaskets be 8, I think I'm missing one of the thinner gaskets for the cylinders am I correct?
| Jake Raby |
Jan 31 2007, 05:54 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
NO head gaskets!
VW said so themselves in 1981 with the factory bulletin on the subject. Head gaskets are evil- |
StratPlayer Gasket Jan 31 2007, 04:21 PM
Headrage Are you gonna run the head gaskets? If not, I wou... Jan 31 2007, 04:27 PM
bahnzai Yes, thin ones are for the cylinder to case seal a... Jan 31 2007, 05:46 PM
StratPlayer What about the cylinder gaskets, In your video you... Jan 31 2007, 07:01 PM
type47 bulletin Jan 31 2007, 07:22 PM
ClayPerrine
bulletin
If you read the bulletin.. it says ... Jan 31 2007, 09:01 PM
Al Meredith Check the thin (cylinder to case) ones ; they stic... Jan 31 2007, 07:43 PM
brp914 I bought an elring set recently and parts were mis... Jan 31 2007, 08:05 PM
StratPlayer Yep, I checked to see if any of those were stuck t... Jan 31 2007, 08:50 PM
sean_v8_914 type II and Vanagon used teh type 4 engine after t... Feb 1 2007, 09:49 AM
ClayPerrine
type II and Vanagon used teh type 4 engine after ... Feb 1 2007, 12:21 PM
Aaron Cox just lots of research and experience that say othe... Feb 1 2007, 12:26 PM
StratPlayer Question of the year, should one USE headgaskets, ... Feb 1 2007, 12:31 PM
Aaron Cox 2 schools of thought.
YES and NO :P
YES - the ... Feb 1 2007, 12:37 PM
Brando After tearing down about 8 TIVs for 914 owners at ... Feb 1 2007, 06:43 PM
McMark Check your deck height. I only consider the cylin... Feb 1 2007, 06:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 06:11 AM |
