| StratPlayer |
Jan 31 2007, 04:21 PM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,383 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
Been looking at the gaskets that came with the gasket kit I bought. The gaskets for the cyl. and heads total 7,, 3 alum. gaskets thin, 4 smaller but thicker alum. gaskets. Shouldn't the total for these gaskets be 8, I think I'm missing one of the thinner gaskets for the cylinders am I correct?
| StratPlayer |
Feb 1 2007, 12:31 PM
Question of the year, should one USE headgaskets, or should one NOT USE headgaskets. As a first time engine builder of the type 4 this issue sure has me confused. I bet any other first time builders find this confusing as well. Some for, some against, leaves me in the middle wondering which direction to go.
StratPlayer Gasket Jan 31 2007, 04:21 PM
Headrage Are you gonna run the head gaskets? If not, I wou... Jan 31 2007, 04:27 PM
bahnzai Yes, thin ones are for the cylinder to case seal a... Jan 31 2007, 05:46 PM
Jake Raby NO head gaskets!
VW said so themselves in 198... Jan 31 2007, 05:54 PM
StratPlayer What about the cylinder gaskets, In your video you... Jan 31 2007, 07:01 PM
type47 bulletin Jan 31 2007, 07:22 PM
ClayPerrine
bulletin
If you read the bulletin.. it says ... Jan 31 2007, 09:01 PM
Al Meredith Check the thin (cylinder to case) ones ; they stic... Jan 31 2007, 07:43 PM
brp914 I bought an elring set recently and parts were mis... Jan 31 2007, 08:05 PM
StratPlayer Yep, I checked to see if any of those were stuck t... Jan 31 2007, 08:50 PM
sean_v8_914 type II and Vanagon used teh type 4 engine after t... Feb 1 2007, 09:49 AM
ClayPerrine
type II and Vanagon used teh type 4 engine after ... Feb 1 2007, 12:21 PM
Aaron Cox just lots of research and experience that say othe... Feb 1 2007, 12:26 PM
Aaron Cox 2 schools of thought.
YES and NO :P
YES - the ... Feb 1 2007, 12:37 PM
Brando After tearing down about 8 TIVs for 914 owners at ... Feb 1 2007, 06:43 PM
McMark Check your deck height. I only consider the cylin... Feb 1 2007, 06:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 06:12 AM |
