> How can I tell if a Boge strut insert is good?
rhcb914
post Feb 4 2007, 09:10 AM
member
I just replaced my rear KYB's and front Boge's with Bilsteins. The KYB's I could tell were good since they are gas charged when I pressed the shaft down it came back up. I know the Boge's aren't gas charged so how can I tell if they are still good? When I press them down there is signigicant resistance, same with pulling the shaft back up.
-Rob
Eric_Shea
post Feb 4 2007, 03:38 PM
PMB Performance
Then they're more than likely good. Both should be the same. Make sure there's no fluid leaks on the shafts. The resistance test you did is the way I gauge all my hydraulic shocks.
- Lo-Fi Version Time is now: 16th June 2024 - 10:02 PM
