Oil pump studs, ...and other (stupid) questions |
yeahmag |
Feb 5 2007, 11:02 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Making a bit of progress, but it's a 2 steps forwards, one step back affair...
I buttoned the short block up the other night and ran in to two problems. Jakes modified Type I pump and cover were a bit big for the stock studs, what I've done thus far is used no lock washer and torqued the nuts down with blue loctite. I also managed to buy Type I instead of Type IV case sealing nuts, so I had to assemble it with the old nuts. I put Curil T on both sides of the case washers just in case I couldn't (for whatever reason) re-torque the case wit the correct nuts. Opinions on what to do about both of these? I was thinking of leaving the oil pump alone and getting the correct nuts for the case and replacing them one at a time. -Aaron |
So.Cal.914 |
Feb 6 2007, 12:08 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
You mean without removing the pump? If you didn't have enough room to put on
the washers it might be hard to remove the stud. IMHO save yourself some anguish and pull the pump. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:56 PM |
