> afm calibration, anyone know how to do it
mattp
post Feb 7 2007, 08:12 PM
anyone know how to calibrate one for a 1.8 engine?
When I open my throttle the sweeper does not go all the way?
Bleyseng
post Feb 8 2007, 12:16 AM
Aircooled Baby!
Use the LM1 meter and adjust the sweeper (loosen that tiny screw) very slightly to set the AFR to 14 to 1 under load driving. Should be stable from idle to WOT otherwise you have some other problem.
Worked great on my bus with Ljet. See pic on other post.
banger
post Feb 8 2007, 02:10 AM
You probably want to run a little lower than 14 for better power, and a little cooler running.
mattp   afm calibration   Feb 7 2007, 08:12 PM
ClayPerrine   anyone know how to calibrate one for a 1.8 engine...   Feb 7 2007, 09:01 PM
Cap'n Krusty   anyone know how to calibrate one for a 1.8 engin...   Feb 9 2007, 11:36 AM
jim_hoyland   When a rebuild meant for a VW is used on a 914, wh...   Feb 7 2007, 09:22 PM
banger   You can use a wideband O2 sensor to calibrate it, ...   Feb 7 2007, 11:33 PM
Mueller   anyone know how to calibrate one for a 1.8 engine...   Feb 7 2007, 11:38 PM
Bleyseng   Use the LM1 meter and adjust the sweeper (loosen t...   Feb 8 2007, 12:16 AM
banger   You probably want to run a little lower than 14 fo...   Feb 8 2007, 02:10 AM
Bleyseng   You can try 13.7 to 1 but that seemed too rich in ...   Feb 8 2007, 10:15 AM
Bleyseng   pic of inside of the AFM. Loosen the screw after r...   Feb 8 2007, 01:01 PM
jim_hoyland   Nice illustration of te AFM adjustment; what is an...   Feb 9 2007, 06:08 AM
jd74914   Its a wideband O2 sensor Jim.   Feb 9 2007, 09:35 AM
Bleyseng   http://www.innovatemotorsports.com/products/lm1.ph...   Feb 9 2007, 10:12 AM
jim_hoyland   Thanks for posting the link. Thats very interestin...   Feb 9 2007, 08:49 PM
banger   If you need one some time, I have one Jim. could ...   Feb 9 2007, 11:23 PM
jim_hoyland   Update. Thanks Chris for bringing your wideband se...   Feb 10 2007, 06:46 PM
Bleyseng   So what is the difference in the AFM as the part n...   Feb 9 2007, 03:28 PM
Bleyseng   Great tuning tool for $400! :trophy: I h...   Feb 9 2007, 10:58 PM
Bleyseng   Well, tell us what your readings were! Share...   Feb 11 2007, 12:59 AM
banger   Readings were around 14.2-14.5 at idle, and 13.5 a...   Feb 11 2007, 01:55 AM
bd1308   man tuning that afm blindly is harder than my rust...   Feb 11 2007, 03:00 AM
Bleyseng   A mite lean I'd say   Feb 11 2007, 11:23 AM
jim_hoyland   Interestingly it doesn't run hot like it had b...   Feb 11 2007, 02:23 PM
Bleyseng   ok, check this out on adjusting the AFM arm.   Feb 11 2007, 02:43 PM
jim_hoyland   K- Thanks.   Feb 11 2007, 04:32 PM
- Lo-Fi Version Time is now: 2nd December 2025 - 09:43 AM
