> afm calibration, anyone know how to do it
mattp
post Feb 7 2007, 08:12 PM
anyone know how to calibrate one for a 1.8 engine?
When I open my throttle the sweeper does not go all the way?
Bleyseng
post Feb 9 2007, 10:12 AM
Aircooled Baby!
http://www.innovatemotorsports.com/products/lm1.php
jim_hoyland
post Feb 9 2007, 08:49 PM
Get that VIN ?
Thanks for posting the link. Thats very interesting.
QUOTE(Bleyseng @ Feb 9 2007, 08:12 AM) *
banger
post Feb 9 2007, 11:23 PM
If you need one some time, I have one Jim. could bring it to the bbq some time if you wanted to check your car.
QUOTE(jim_hoyland @ Feb 9 2007, 06:49 PM) *
mattp   afm calibration   Feb 7 2007, 08:12 PM
ClayPerrine   anyone know how to calibrate one for a 1.8 engine...   Feb 7 2007, 09:01 PM
Cap'n Krusty   anyone know how to calibrate one for a 1.8 engin...   Feb 9 2007, 11:36 AM
jim_hoyland   When a rebuild meant for a VW is used on a 914, wh...   Feb 7 2007, 09:22 PM
banger   You can use a wideband O2 sensor to calibrate it, ...   Feb 7 2007, 11:33 PM
Mueller   anyone know how to calibrate one for a 1.8 engine...   Feb 7 2007, 11:38 PM
Bleyseng   Use the LM1 meter and adjust the sweeper (loosen t...   Feb 8 2007, 12:16 AM
banger   You probably want to run a little lower than 14 fo...   Feb 8 2007, 02:10 AM
Bleyseng   You can try 13.7 to 1 but that seemed too rich in ...   Feb 8 2007, 10:15 AM
Bleyseng   pic of inside of the AFM. Loosen the screw after r...   Feb 8 2007, 01:01 PM
jim_hoyland   Nice illustration of te AFM adjustment; what is an...   Feb 9 2007, 06:08 AM
jd74914   Its a wideband O2 sensor Jim.   Feb 9 2007, 09:35 AM
Bleyseng   http://www.innovatemotorsports.com/products/lm1.ph...   Feb 9 2007, 10:12 AM
jim_hoyland   Thanks for posting the link. Thats very interestin...   Feb 9 2007, 08:49 PM
banger   If you need one some time, I have one Jim. could ...   Feb 9 2007, 11:23 PM
jim_hoyland   Update. Thanks Chris for bringing your wideband se...   Feb 10 2007, 06:46 PM
Bleyseng   So what is the difference in the AFM as the part n...   Feb 9 2007, 03:28 PM
Bleyseng   Great tuning tool for $400! :trophy: I h...   Feb 9 2007, 10:58 PM
Bleyseng   Well, tell us what your readings were! Share...   Feb 11 2007, 12:59 AM
banger   Readings were around 14.2-14.5 at idle, and 13.5 a...   Feb 11 2007, 01:55 AM
bd1308   man tuning that afm blindly is harder than my rust...   Feb 11 2007, 03:00 AM
Bleyseng   A mite lean I'd say   Feb 11 2007, 11:23 AM
jim_hoyland   Interestingly it doesn't run hot like it had b...   Feb 11 2007, 02:23 PM
Bleyseng   ok, check this out on adjusting the AFM arm.   Feb 11 2007, 02:43 PM
jim_hoyland   K- Thanks.   Feb 11 2007, 04:32 PM
- Lo-Fi Version Time is now: 2nd December 2025 - 09:43 AM
