> 914 1.8 fuel flow questions
michaelmoo
post Feb 10 2007, 03:59 AM
I need some one to explain something to me. I was looking at the diagram on Pelican and something didn’t seem right. If you follow the “Flow” arrows you don’t reduce the fuel pressure until after it goes to the injectors. Shouldn’t the fuel pressure regulator get the higher pressure fuel from the pump before the injectors? Maybe I don’t fully understand, but it just doesn’t make since to me.
I’m redoing all the fuel lines in my car (was carbs, but going back to FI) and need to know if the Pelican diagram is correct. Help please!!!
Thanks, Mike
Bleyseng
post Feb 10 2007, 09:54 AM
Aircooled Baby!
Yes, the straight out port is the return port/line. Just make sure the feed/druck line is hooked up correctly to the fuel injectors.
- Lo-Fi Version Time is now: 17th July 2025 - 04:51 AM
