| mattp |
Feb 7 2007, 08:12 PM
Member ![]() ![]() Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
anyone know how to calibrate one for a 1.8 engine?
When I open my throttle the sweeper does not go all the way? |
| bd1308 |
Feb 11 2007, 03:00 AM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
man tuning that afm blindly is harder than my rust repair...
mattp afm calibration Feb 7 2007, 08:12 PM
ClayPerrine
anyone know how to calibrate one for a 1.8 engine... Feb 7 2007, 09:01 PM
Cap'n Krusty
anyone know how to calibrate one for a 1.8 engin... Feb 9 2007, 11:36 AM
jim_hoyland When a rebuild meant for a VW is used on a 914, wh... Feb 7 2007, 09:22 PM
banger You can use a wideband O2 sensor to calibrate it, ... Feb 7 2007, 11:33 PM
Mueller
anyone know how to calibrate one for a 1.8 engine... Feb 7 2007, 11:38 PM
Bleyseng Use the LM1 meter and adjust the sweeper (loosen t... Feb 8 2007, 12:16 AM
banger You probably want to run a little lower than 14 fo... Feb 8 2007, 02:10 AM
Bleyseng You can try 13.7 to 1 but that seemed too rich in ... Feb 8 2007, 10:15 AM
Bleyseng pic of inside of the AFM. Loosen the screw after r... Feb 8 2007, 01:01 PM
jim_hoyland Nice illustration of te AFM adjustment; what is an... Feb 9 2007, 06:08 AM
jd74914 Its a wideband O2 sensor Jim. Feb 9 2007, 09:35 AM
Bleyseng http://www.innovatemotorsports.com/products/lm1.ph... Feb 9 2007, 10:12 AM
jim_hoyland Thanks for posting the link. Thats very interestin... Feb 9 2007, 08:49 PM
banger If you need one some time, I have one Jim. could ... Feb 9 2007, 11:23 PM
jim_hoyland Update.
Thanks Chris for bringing your wideband se... Feb 10 2007, 06:46 PM
Bleyseng So what is the difference in the AFM as the part n... Feb 9 2007, 03:28 PM
Bleyseng Great tuning tool for $400! :trophy: I h... Feb 9 2007, 10:58 PM
Bleyseng Well, tell us what your readings were! Share... Feb 11 2007, 12:59 AM
banger Readings were around 14.2-14.5 at idle, and 13.5 a... Feb 11 2007, 01:55 AM
Bleyseng A mite lean I'd say Feb 11 2007, 11:23 AM
jim_hoyland Interestingly it doesn't run hot like it had b... Feb 11 2007, 02:23 PM
Bleyseng ok, check this out on adjusting the AFM arm. Feb 11 2007, 02:43 PM
jim_hoyland K-
Thanks. Feb 11 2007, 04:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd December 2025 - 09:43 AM |
