> Type-4 Dry Sump System, Any Thoughts, Ideas, Comments?
Britain Smith
post Nov 17 2003, 06:23 PM
Nano Member
I am toying with the idea of installing a dry sump system on my turbo type-4 conversion in my 912. I have the room to mount a 911-style oil tank in the stock fender location and can run a fender mounted oil cooler up front. I also need a way to keep the turbo properly oiled. Does anyone have any experience with this? How might one plum this system up? Where can I get a dry sump pump for this purpose?
-Britain
Mark Henry
post Nov 17 2003, 07:23 PM
that's what I do!
I've seen them and held them but never saw the need for them. Again I'm talking type 1 drag experience. I could see it (maybe) for racing and long sweepers, but a modified windage tray and tuna can would solve that.
My choice would be a type 1 30mm schadek pump with a Berg pressure relief cover. You can't use this on a 914 because of the engine bar mounts, so you would have to check if you can full flow your 912. Even the 26mm Schadek should be fine with the turbo.
- Lo-Fi Version Time is now: 2nd April 2026 - 04:25 PM
