Windshield Frame Seal, Anyone put a new one in lately? |
tyler |
Feb 16 2007, 03:06 PM
Member Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 |
I'm trying to put in my $1200 seal which I got on Ebay awhile ago, thankfully for $180 but still I'm a nervous wreck working on it considering it's value. It's a real bear to get in. First I had to spread the seam along it at the top of the windshield to get it to snap in. Now I can't get the side pieces to fit down into the trim strip, especially at the top where it makes the sharp bend. I've even been trying to slide the side pieces in the trim off the car and maybe spread it to get the screws in afterwards but that's not going well.
I doubt if anyone's put in a new one lately, but is so can you offer any tips? Attached image(s) |
John |
Feb 16 2007, 03:40 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
You need to mount the trim to the car first.
I use rubber lubricant from here: P-80 Temporary Rubber Lubricant This will not harm the rubber, and will make it slick enough to easily work into the channels. I start on one side and have a partner support the remainder of the rubber to eliminate stress at the two corner joints (which can break easily). I work one side pushing/pulling/stretching the rubber down the channel. Once it is nearly down, you must carefully work the corner onto the top of the channel. Once it is started, you can finish pushing/pulling/stretching the seal down the channel. Next work the seal part way across the top (about 1/3 of the way across) This just helps support the rubber seal. Work the second side down the channel on the opposite side the same as you did the first, being extra careful when it gets close to the corner engaging the top of the channel. When both sides are fed down the channels, work the remainder of the seal across the top of the windshield. Lastly, when the seal is in place, you may need to slightly crimp the channels (just as the factory did) to hold the seal in place. The last one I did, I didn't have to do this, but it was an old seal. I am about ready to replace an old cracked seal as well, but I have not yet had the time. Maybe this weekend....... Good luck. |
Lo-Fi Version | Time is now: 7th June 2024 - 04:50 PM |
