> Rear trunk torsion bar removal
watsonrx13
post Feb 20 2007, 07:09 PM
Does anyone have a link to the posting showing the home-made tool and technique for removing the torsion bars holding the rear trunk?
I need to replace/reweld the trunk hinge bracket. I'm planning to remove the torsion bars, then remove the rest of the old bracket, clean up the old weld and/or any metal missing from the inner fender well, then postion the trunk, with the new bracket attached, and weld the new bracket on.
Any other suggestions, comments, observations, prayers, etc?
BTW, the search function doesn't work too well....
-- Rob
degreeoff
post Feb 20 2007, 07:12 PM
I like big butts and I can not lie!
I am no expert I only did it once....and that was enough! OK twice. The first time I used a box end wrench with a slot cut in it to pry the bar back and undo the hinge....the second time I actually took the bars off and damn near killed myself I cut the brackets off and stood back.....sheet .....I'll follow this one
watsonrx13   Rear trunk torsion bar removal   Feb 20 2007, 07:09 PM
degreeoff   I am no expert I only did it once....and that was ...   Feb 20 2007, 07:12 PM
ahdoman   Use the JWest trunk pivots (http://www.jwesteng.co...   Feb 20 2007, 07:25 PM
914Sixer   I have the factory tool if you want to borrow it....   Feb 20 2007, 08:43 PM
watsonrx13   I have the factory tool if you want to borrow it...   Mar 5 2007, 07:43 PM
LowGT   I removed them with the unbolt nuts and watch it f...   Feb 20 2007, 09:35 PM
Brando   I removed them with the unbolt nuts and watch it f...   Mar 6 2007, 10:07 AM
Porcharu   I removed them with the unbolt nuts and watch it ...   Mar 7 2007, 01:04 AM
swood   I used the leave bolted on and cut with a sawzall ...   Feb 20 2007, 10:06 PM
boxstr   I have done a few torsion rod removals. Easy way i...   Feb 20 2007, 10:37 PM
Twystd1   I use an Aaron. (It's like a factory TOOL) I ...   Feb 21 2007, 02:17 AM
Grimstead   I use an Aaron. over 230LBs soaking wet out of t...   Feb 21 2007, 08:36 AM
SGB   use a 10-mm ( I think thats the right size) deep w...   Feb 21 2007, 07:15 AM
SLITS   use a 10-mm ( I think thats the right size) deep ...   Feb 21 2007, 07:26 AM
cooltimes   [quote name='SGB' post='865691' date='Feb 21 2007...   Feb 21 2007, 07:57 AM
type47   this it?   Feb 21 2007, 08:50 AM
cooltimes   this it? That's very like the Porsche facto...   Feb 21 2007, 09:03 AM
watsonrx13   Thanks to everyone for your recommendations (I...   Feb 21 2007, 06:17 PM
Scott-thundercat   yeah i did this too at pick and pull- i damn nea...   Feb 21 2007, 10:06 PM
ClayPerrine   There is a simpler tool that is probably already i...   Feb 21 2007, 10:15 PM
Brando   My favorite solution... Take an angle grinder, cu...   Feb 21 2007, 11:57 PM
highways   I made a tool that worked great. I took about 2...   Feb 22 2007, 01:21 AM
914Sixer   As soon as the torsion bar tool returns, it will b...   Mar 5 2007, 07:47 PM
rdauenhauer   As soon as the torsion bar tool returns, it will ...   Mar 5 2007, 11:27 PM
wbergtho   I used the same method and wished I had my full f...   Mar 5 2007, 10:54 PM
Jeffs9146   Classic Tread Here is the link!   Sep 8 2010, 04:08 PM
mstein95   I thought I remembered Rhodyguy doing a "how ...   Sep 8 2010, 04:37 PM
TargaToy   My dad was just about to utter the word "tors...   Sep 8 2010, 09:13 PM
steveherman   saw how old this thread is... edit   Sep 8 2010, 09:46 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:26 AM
