Tough cold-starts w/chokeless Webers..., any secrets from you northerners? |
PinetreePorsche |
Feb 20 2007, 08:57 AM
Member Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
My 2.0 w/ Webers will fire, catch for an instant,and die. Each re-start, the instant stretches out, till, on the 4th try, it runs for maybe one second, and the 6th or 7th it goes for 2-3 sec, and maybe the 10th or 12th, it will stay running with lots of artful foot flutter on the gas. Less artful and it dies--until it has had about 15-20 sec of uninterrupted running with the foot flutter. Even then it needs just a slightly high rev, like 1800 (hate to do that when it's still cold), then, after another half min, I can let the foot off the pedal and it'll stay running. Then, maybe another 15 sec, I can lift my clutch foot and not have the extra load of the heavy oil kill it again (maybe keeping the revs at 1000 with my foot). Finally, after 2 min total I can get underway, if I over-rev it pulling away in 1st. Still, it will back-fart a bit if I gas it too much after a shift to too low a rev. By 5 min, as the heat starts to come out on the glass, it gets more normal. SO: you far northerners with carbs --what can I do with choke-less Webers to make this a kinder, gentler process? (Yes, if there's salt on the roads --last 3 weeks here-- I leave it at home. But the warm and rain are coming for 2-3 days, so it will get out again, and I'd love to do right by it.)
Eric_Shea |
Feb 20 2007, 07:23 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
MFI sucks... (IMG:style_emoticons/default/poke.gif)
I have dual 40IDA3C's. For me this is a standard operating procedure when cold starting the car to keep it lubed up in the winter. My carbs. are like new. 1. Let the fuel pump run for a few seconds to fill the bowls (I don't start it often). 2. Pump 10 times. 3. Crank and feather the throttle. |
911quest |
Feb 20 2007, 08:07 PM
Member Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States |
Now you know why later carbed Prosches came with a hand throttle
Lo-Fi Version | Time is now: 11th June 2024 - 12:00 AM |
