| BiG bOgGs |
Feb 24 2007, 07:05 PM
The Bogus One ![]() ![]() Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
Hi all, I am presently checking out a 76 teener that Rob Watson is selling. (It's the one he is fixing the torsion bar on) The PO already did a 5 lug conversion and has the front calipers on the rear now, which means no e-brake. Is there any way to fit on or modify anything to add an e-brake anywhere in the system. My drive way is steep enough that I will feel very uncomfortable leaving it just parked in gear, and don't want to always have to put a block behind the weels. Any suggestiond on what to do or where to search are greatly appreciated.
(IMG:style_emoticons/default/pray.gif) |
| 736conver |
Feb 24 2007, 08:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
BiG bOgGs 5 Lug E-Brake? Feb 24 2007, 07:05 PM
Aaron Cox you can use a 911 ebrake setup with 911 rotors. i ... Feb 24 2007, 07:12 PM
davep You could go with stock 914/4 or 914/6 calipers. Y... Feb 24 2007, 08:05 PM
BiG bOgGs
You could go with stock 914/4 or 914/6 calipers. ... Feb 24 2007, 08:14 PM
736conver
You could go with stock 914/4 or 914/6 calipers.... Feb 24 2007, 08:22 PM
bondo Doesn't MSDS have a spot caliper kit? Feb 24 2007, 08:32 PM
BiG bOgGs Thanks All! I will be contacting Eric if/when... Feb 24 2007, 08:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:02 PM |
