Tool for cutting metal discs?, Nibbler? Shears? Laser? |
Air_Cooled_Nut |
Nov 18 2003, 10:35 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
What tool do you metal pounders recommend for cutting circles? I welded up the side marker mounting holes and am read to weld in a disc in the large center hole -- don't want to pack that sucker with filler, ya know (IMG:style_emoticons/default/laugh.gif)
BTW, I have very shallow pockets so let's keep costs down (IMG:style_emoticons/default/welder.gif) |
mr914 |
Nov 19 2003, 10:19 AM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
I used blue masking tape from the front side.
I then cut the template out with an exacto knife. I then put the tape template on the sheetmetal. In my case, I called a friend with a plasma cutter. Otherwise, cut close with aviation snips and grind to fit. Good luck. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:28 AM |
