Hydraulic vs solid cam for weekend cruiser, Pros and con |
914Sixer |
Feb 25 2007, 09:09 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I know that the hydraulic is frowned on. All of the later type 4 motors went this route. Even the last Type 1 Beetles from Mexico went there too! The newest 911 are hydraulic.
I am not going racing just crusing in my 73 2.0. I know the power band is different but most of the driving will be under 4500 rpm. I plan on running some modified Hoffman AMC 2.0 heads, 94mm Euro pistons, 1.7 rockers with 911 swivel feet, solid rocker spacers and stock FI. Nothing exotic. |
ahdoman |
Feb 25 2007, 09:56 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Mark,
I'll chime in hear since I currently own a 74 2.0 with hydro's. When I purchsed the car one of the hydros was airlocked. It took a lot of research to figure that out and I finally got the air out and it operates fine. I am really pretty happy with the hydros. I do not race or do AX but I do drive the car fairly hard. I currently have my engine out of the car and am beginning a minor clean and rebuild. I am going to keep my hydros because now that they have settled in they are really easy to live with. Here are a couple of tips I have found... 1) Use good synthetic oil. I run Royal Purple. All it takes is a little spec of dirt to clog a hydro. Synth helps to keep em clean. 2) Prior to changing the oil put a can of Marvel Mystery Oil in the case and drive it good for a couple of days. I usually try to put about 500 miles on the car once I've done that. The Marvel oil will help to loosen any of the gunk that may have clogged a lifter. 3) Supposedly you only have to adjust the hydros every 10k miles or so. I still check mine occasionaly. That has made it possible for me to find thier "happy place" for adjustment (mine is at about 1.25 turns past contact). 4) Here are a couple of web pages dedicated to hydros that help me a lot... http://www.ratwell.com/technical/HydraulicLifters.html http://www.bostonengine.com/articles/hydraulicll.htm I like mine, I'm keeping them. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:20 PM |
