1bad914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 ![]() |
I cannot believe that I am going to ask this, (big carb guy) but here I go. I just finished building a 1911 motor, it is based around an EA motor with 96 mm pistons and cylinders, the only other aftermarket thing is a Webcam 86 cam. I currently have dual DRLA 36 carbs on it now. I am thinking about putting fuel injection on this motor, I have access to a lot of FI components and really would like to give FI a try, I want to drive this everyday and thought it would be nice, I have a friend that is very familiar with Type I FI and has offered to help.
With the motor specs above what FI system would you recommend, I need specs like what brain box, injectors, dizzy...i Is this even possible with this cam, I would like to use stock FI, and not mess with a Mega squirt. Any advice would be appreciated. I really just want to learn about FI and this is one way to do it. |
krazykonrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,153 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 ![]() |
I've had good luck with stock D-jet FI in several different applications. I'm not knowledgable enough to know how that will work with your cam. Jake would. If you have a stock system availible, it may well be worth a try. Mega squirt is way more adjustable, but sometimes wide adjustability is a easy trap to fall into.
Konrad |
Lo-Fi Version | Time is now: 19th July 2025 - 09:52 AM |
