smj |
"Dude, Steve from Berkeley." ![]() ![]() ![]() Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California ![]() ![]() |
So a month or two ago I went four or maybe six weeks without running the 3.0l SC motor in my 914-6. I had been firing it up every other weekend, but things happened.... Anyway, no joy regardless of where the hand throttle sits. Every now and again it taunts me by sounding as if it fired on one revolution.
The motor is carbed, not fuel injected. Plenty of juice in the battery, the starter motor is happy to turn, there's gas in the tank. I know I need fuel, air, and spark -- the question is how to check that these things are getting to where they need to go. I feel a thrumming in the engine bay fuel lines when the key is in the right position, and I can hear the fuel pump running. How do I confirm that I'm getting a pulse to the spark plugs without a clamp-type electrical meter? Links to tutorials would be welcome. I did try a couple of searches before posting, but the keywords I used must've been way too broad... Thanks, --Steve. |
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
Are you only useing the hand throttle when trying to start? Or are you giving the throttle pedal a "pump" to the floor to squirt fuel into the engine and then setting the hand throttle? I'm thinking if the car has sat for 6 weeks and if your only useing the hand throttle your not getting enough fuel to start the engine. To check spark remove the easiest to reach spark plug then reconnect the removed plug to the wire. Hold the spark end close to the engine and have someone turn the starter motor on you should see spark at the spark plug end.Good luck.
Lo-Fi Version | Time is now: 11th July 2025 - 07:12 AM |
