> What's the max displacement stock L-jet can handle?
newto914s
post Mar 4 2007, 02:30 AM
I know that because of the Air mass sensor on the L-jet it can handle some slight increases of displacement without too much trouble. Engine sucks in a little more air and it compensates with-in reason.
So I'm wondering where the line is if you just increase the bore size where the L-jet will not be able richen the mixture enough. 96mm, 100mm, 103. I've heard some guys use the 1.8 L-jet on the 2.0, so a 10% increase. So if your starting with a 2.0 bus L-jet system it should be able to handle 2.2 liters, right?
Brando
post Mar 4 2007, 05:23 PM
BUY MY SPARE KIDNEY!!!
Turbo application...
Twin turbos, one AFS on each side intake to turbo, two brains, 8 injectors maybe?
newto914s   What's the max displacement stock L-jet can handle?   Mar 4 2007, 02:30 AM
ClayPerrine   The L-Jet system can handle as much displacement a...   Mar 4 2007, 07:23 AM
cantley914   But the L-Jet system is real good for turbo mot...   Mar 4 2007, 07:45 AM
newto914s   I'm wondering what that limit is before recali...   Mar 4 2007, 08:15 AM
MrKona   How does one recalibrate the AFM? What does this ...   Mar 4 2007, 10:17 AM
Bleyseng   Reset the AFM by moving the arm. You must use a O2...   Mar 4 2007, 10:28 AM
Brando   After re-calibrating the AFS you can then change y...   Mar 4 2007, 10:51 AM
ClayPerrine   The only other thing you will need to change for B...   Mar 4 2007, 11:03 AM
Bleyseng   Yes, you will have to adjust the spring tension on...   Mar 4 2007, 03:30 PM
914nerd   But the L-Jet system is real good for turbo moto...   Mar 4 2007, 04:57 PM
ClayPerrine   But the L-Jet system is real good for turbo mot...   Mar 4 2007, 11:00 PM
Brando   Turbo application... Twin turbos, one AFS on each...   Mar 4 2007, 05:23 PM
Aaron Cox   you make things waaay too complicated....   Mar 4 2007, 06:45 PM
tdgray   you make things waaay too complicated.... :ag...   Mar 4 2007, 06:52 PM
newto914s   Reset the AFM by moving the arm. You must use a O...   Mar 4 2007, 09:16 PM
bd1308   anything over 96's and you get cooling issues   Mar 4 2007, 09:52 PM
Bleyseng   Clay, Djet had a non-adjustable regulator, Ljet co...   Mar 5 2007, 09:35 AM
newto914s   :agree:   Mar 5 2007, 09:55 AM
Jake Raby   2056cc safely. I have proven this time and time ag...   Mar 5 2007, 10:19 AM
- Lo-Fi Version Time is now: 1st July 2025 - 07:57 AM
