newto914s |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 ![]() |
I know that because of the Air mass sensor on the L-jet it can handle some slight increases of displacement without too much trouble. Engine sucks in a little more air and it compensates with-in reason.
So I'm wondering where the line is if you just increase the bore size where the L-jet will not be able richen the mixture enough. 96mm, 100mm, 103. I've heard some guys use the 1.8 L-jet on the 2.0, so a 10% increase. So if your starting with a 2.0 bus L-jet system it should be able to handle 2.2 liters, right? |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
you make things waaay too complicated....
tdgray |
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None ![]() |
you make things waaay too complicated.... (IMG:style_emoticons/default/agree.gif) There are much easier ways to go about this. Megasquirt for example. Sure tuning is a bitch but once you have it you have it (or so I am told... hey I teach therefore I cannot do (IMG:style_emoticons/default/smile.gif)) |
Lo-Fi Version | Time is now: 1st July 2025 - 06:46 AM |
