newto914s |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 ![]() |
I know that because of the Air mass sensor on the L-jet it can handle some slight increases of displacement without too much trouble. Engine sucks in a little more air and it compensates with-in reason.
So I'm wondering where the line is if you just increase the bore size where the L-jet will not be able richen the mixture enough. 96mm, 100mm, 103. I've heard some guys use the 1.8 L-jet on the 2.0, so a 10% increase. So if your starting with a 2.0 bus L-jet system it should be able to handle 2.2 liters, right? |
914nerd |
Who you callin' a "Member"? ![]() ![]() Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 ![]() |
But the L-Jet system is real good for turbo motors. Do explain. How does one go about setting up the L-Jet for a turbo motor? (Yes, I know you can't turbo a 914, but that doesn't mean you can't try, right) (IMG:style_emoticons/default/biggrin.gif) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,414 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
But the L-Jet system is real good for turbo motors. Do explain. How does one go about setting up the L-Jet for a turbo motor? (Yes, I know you can't turbo a 914, but that doesn't mean you can't try, right) (IMG:style_emoticons/default/biggrin.gif) Turbo goes between the AFM and the throttle body. the extra boost is handled by the AFM, just readjust the spring tension to keep it from pegging out under full boost, and adjust the wiper for the mixture. If you need more fuel pressure, swap the regulator for a D-jet adjustable regulator. |
Lo-Fi Version | Time is now: 1st July 2025 - 03:01 PM |
