| watsonrx13 |
Feb 20 2007, 07:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Does anyone have a link to the posting showing the home-made tool and technique for removing the torsion bars holding the rear trunk?
I need to replace/reweld the trunk hinge bracket. I'm planning to remove the torsion bars, then remove the rest of the old bracket, clean up the old weld and/or any metal missing from the inner fender well, then postion the trunk, with the new bracket attached, and weld the new bracket on. Any other suggestions, comments, observations, prayers, etc? ![]() BTW, the search function doesn't work too well.... -- Rob |
| 914Sixer |
Mar 5 2007, 07:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,492 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
As soon as the torsion bar tool returns, it will be available for who ever needs it. Let me know. You pay the postage.
Thanks, Mark. |
watsonrx13 Rear trunk torsion bar removal Feb 20 2007, 07:09 PM
degreeoff I am no expert I only did it once....and that was ... Feb 20 2007, 07:12 PM
ahdoman Use the JWest trunk pivots (http://www.jwesteng.co... Feb 20 2007, 07:25 PM
914Sixer I have the factory tool if you want to borrow it.... Feb 20 2007, 08:43 PM
watsonrx13
I have the factory tool if you want to borrow it... Mar 5 2007, 07:43 PM
LowGT I removed them with the unbolt nuts and watch it f... Feb 20 2007, 09:35 PM
Brando I removed them with the unbolt nuts and watch it f... Mar 6 2007, 10:07 AM
Porcharu
I removed them with the unbolt nuts and watch it ... Mar 7 2007, 01:04 AM
swood I used the leave bolted on and cut with a sawzall ... Feb 20 2007, 10:06 PM
boxstr I have done a few torsion rod removals.
Easy way i... Feb 20 2007, 10:37 PM
Twystd1 I use an Aaron. (It's like a factory TOOL)
I ... Feb 21 2007, 02:17 AM
Grimstead
I use an Aaron. over 230LBs soaking wet out of t... Feb 21 2007, 08:36 AM
SGB use a 10-mm ( I think thats the right size) deep w... Feb 21 2007, 07:15 AM
SLITS
use a 10-mm ( I think thats the right size) deep ... Feb 21 2007, 07:26 AM
cooltimes
[quote name='SGB' post='865691' date='Feb 21 2007... Feb 21 2007, 07:57 AM
type47 this it? Feb 21 2007, 08:50 AM
cooltimes
this it?
That's very like the Porsche facto... Feb 21 2007, 09:03 AM
watsonrx13 Thanks to everyone for your recommendations (I... Feb 21 2007, 06:17 PM
Scott-thundercat
yeah i did this too at pick and pull- i damn nea... Feb 21 2007, 10:06 PM
ClayPerrine There is a simpler tool that is probably already i... Feb 21 2007, 10:15 PM
Brando My favorite solution...
Take an angle grinder, cu... Feb 21 2007, 11:57 PM
highways I made a tool that worked great. I took about 2... Feb 22 2007, 01:21 AM
rdauenhauer
As soon as the torsion bar tool returns, it will ... Mar 5 2007, 11:27 PM
wbergtho
I used the same method and wished I had my full f... Mar 5 2007, 10:54 PM
Jeffs9146 Classic Tread
Here is the link! Sep 8 2010, 04:08 PM
mstein95 I thought I remembered Rhodyguy doing a "how ... Sep 8 2010, 04:37 PM
TargaToy My dad was just about to utter the word "tors... Sep 8 2010, 09:13 PM
steveherman saw how old this thread is... edit Sep 8 2010, 09:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:43 AM |
