CV joint assembly, writeup? |
yarin |
Mar 8 2007, 08:07 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Does anyone have a writeup on how to install a CV joint on the axle?
I'm uncertain of which goes first and in what direction. Here is a pic of the kit: (IMG:http://www.pmbperformance.com/i//CV_Joint_Kit.jpg) Thanks |
IronHillRestorations |
Mar 10 2007, 12:03 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The last set I rebuilt required using a press to allow enough clearance for the snap ring. It required compressing the concave washer a little more than what I remember from prior CV replacements. I was using all pretty much all new parts though; CV's, boots, concave washers, snap rings, etc. The only part that was used was the actual drive shaft. YMMV
yarin |
Mar 10 2007, 12:07 PM
The last set I rebuilt required using a press to allow enough clearance for the snap ring. It required compressing the concave washer a little more than what I remember from prior CV replacements. I was using all new parts though; CV's, boots, concave washers, snap rings, etc. YMMV Which snap ring did you use? The C-clip with tool holes(pictured in the factory manual) or other one that's twice as thick? |
Lo-Fi Version | Time is now: 1st June 2024 - 05:23 PM |
