> Boxster Brakes, Which to get? S or Non S?
soloracer
post Mar 18 2007, 11:51 PM
I am looking for a decent brake solution for my 914. Currently the car has an 80's 911 front suspension and I purchased a set of 964 C2 calipers and Carrera rotors. I thought I was doing good until I saw the bolt spacing for the 964 calipers don't match the strut mounts. I found adapters but they require sawing the mounting tabs off the calipers and buying an adapter - to the tune of $1000+. So now I am considering selling the 964 calipers and going with a full set of Boxster units. Question is though, which ones do you go with? The Boxster S or non S? Or should I just scrap the idea of Boxster brakes all together and get 993's or something else? Maybe keep the 964's and redrill the holes? Know anyone who does that sort of work?
Any and all suggestions are appreciated.
Brando
post Mar 19 2007, 12:05 AM
BUY MY SPARE KIDNEY!!!
930 (big reds), 964 and 993 brakes are 3.5" bolt hole spacing. So, you'd have to weld an adapter on for those anyhow. As for Boxsters... I think they are 3.5" spacing as well, but I'm not 100% sure.
soloracer   Boxster Brakes   Mar 18 2007, 11:51 PM
Brando   930 (big reds), 964 and 993 brakes are 3.5" b...   Mar 19 2007, 12:05 AM
smdubovsky   930 (big reds), 964 and 993 brakes are 3.5" ...   Mar 19 2007, 07:49 AM
Aaron Cox   (though you can put boxster calipers on 3" s...   Mar 19 2007, 09:28 AM
smdubovsky   (though you can put boxster calipers on 3" ...   Mar 19 2007, 10:54 AM
Dan (Almaden Valley)   are you sure your struts/spindles are off of an 80...   Mar 19 2007, 12:21 AM
Aaron Cox   im working on a non s swap right now...   Mar 19 2007, 12:25 AM
Aaron Cox   craig downs and i are working on it. this pic sh...   Mar 19 2007, 10:59 AM
Van914   Call Rich Johnson in Texas. He make adapters. I do...   Mar 19 2007, 12:42 PM
Aaron Cox   Call Rich Johnson in Texas. He make adapters. I d...   Mar 19 2007, 12:44 PM
ClayPerrine   If you use 16 inch wheels and the adapters for the...   Mar 19 2007, 12:51 PM
Aaron Cox   If you use 16 inch wheels and the adapters for th...   Mar 19 2007, 12:54 PM
ClayPerrine   If you use 16 inch wheels and the adapters for t...   Mar 19 2007, 12:59 PM
smdubovsky   Aaron, That pic says it all. Tnx. The holes stil...   Mar 19 2007, 01:57 PM
soloracer   Just to be clear, everyone here is talking about n...   Mar 19 2007, 02:32 PM
smdubovsky   Yes, we're talking non-S. The S/996 calipers ...   Mar 19 2007, 04:02 PM
Luke M   I have boge 3.5" spacing struts, with carrera...   Mar 19 2007, 06:01 PM
Aaron Cox   yep... that looks like the TRE kit. thats the bolt...   Mar 19 2007, 06:08 PM
craig downs   With that pic even with the 3.5" spindle and ...   Mar 19 2007, 08:23 PM
LarryR   Call Rich Johnson in Texas. He make adapters. I ...   Mar 19 2007, 08:48 PM
Aaron Cox   i dont think craig or his sandrail shop friend wil...   Mar 19 2007, 08:49 PM
soloracer   Since the Boxster S calipers appear to be a dead e...   Mar 19 2007, 09:11 PM
neo914-6   Since the Boxster S calipers appear to be a dead ...   Mar 20 2007, 04:27 PM
Aaron Cox   you dont gain a whole lot with boxster or 951 cali...   Mar 19 2007, 09:17 PM
craig downs   i dont think craig or his sandrail shop friend wi...   Mar 19 2007, 09:49 PM
LarryR   i dont think craig or his sandrail shop friend w...   Mar 19 2007, 09:52 PM
Matt Romanowski   Is there a reason why no one considers running Wil...   Mar 20 2007, 06:34 AM
soloracer   I wasn't aware that there was a Willwood solut...   Mar 20 2007, 10:56 AM
andys   I wasn't aware that there was a Willwood solu...   Mar 20 2007, 11:07 AM
Aaron Cox   as mentioned... alot of wilwoods bolt up to 3.5...   Mar 20 2007, 11:16 AM
Matt Romanowski   I posted pictures of my setup. A search should fin...   Mar 20 2007, 01:10 PM
DownUnderMan   You mean something like this:   Mar 20 2007, 02:17 PM
Luke M   I dont have any brake pad over hang on my boxster ...   Mar 20 2007, 03:39 PM
- Lo-Fi Version Time is now: 14th April 2026 - 09:41 AM
