> Thinking about Going Carbs, Need a Kit, Need suggestions on a carb Kit for a 74 914
djfamousa
post Mar 20 2007, 05:58 PM
Hi Everyone,
I am thinking about switching over to carbs. My stock FI is proving to be a PITA to fix and is costly. Can anybody recommend a good carb kit for a 74 914 w/ stock motor? All I know is that I heard webber was not good and I also heard something about having to add a cam if changing over to carbs. Can anyone help?
SGB
post Mar 20 2007, 10:35 PM
just visiting
It may cost $2k to put on webers properly, but it will simplify the car. Is the shop a good VW place? If you could go to them for periodic rebalancing and such after they put it in, and they knew what they were doing, it should be reliable. In fact- if you drop the $ for a real shop to do it, i would insist on a two year maintenance agreement- and you get to watch so you learn how to do it yourself. Go no bigger than "40 IDF" Webers, with a 28mm venturi in 'em (thats how a lot are set up anyway).
djfamousa   Thinking about Going Carbs, Need a Kit   Mar 20 2007, 05:58 PM
914nerd   Personally I wouldn't give up on FI just yet A...   Mar 20 2007, 06:04 PM
djfamousa   Personally I wouldn't give up on FI just yet ...   Mar 20 2007, 06:09 PM
914nerd   Parts are expensive, but if you have some electron...   Mar 20 2007, 06:43 PM
djfamousa   Parts are expensive, but if you have some electro...   Mar 20 2007, 07:22 PM
tdsmoonchild   call me old fashioned but I was going to go with d...   Mar 20 2007, 07:31 PM
SirAndy   dual webers or solex will work just fine. the 44...   Mar 20 2007, 08:29 PM
lotus_65   I regret putting carbs on my '74 1.8. It's...   Mar 20 2007, 09:28 PM
SGB   It may cost $2k to put on webers properly, bu...   Mar 20 2007, 10:35 PM
dagdal1967   I just got done (with the help of Clay) putting th...   Mar 21 2007, 09:42 AM
rhodyguy   44s are way to big for your 1.8 unless you spend a...   Mar 21 2007, 10:44 AM
r_towle   With carbs, go with dual 40mm webers or dells. Loo...   Mar 21 2007, 10:50 AM
Carlitos Way   Maybe I'm not the right person to say this bei...   Mar 21 2007, 10:54 AM
Joe Ricard   CARBS ARE NOT EASY I have been running carbs for ...   Mar 21 2007, 11:32 AM
rhodyguy   please share the operational problems your engine ...   Mar 21 2007, 11:37 AM
r_towle   I found it http://manuals.type4.org/ljet Rich   Mar 21 2007, 11:42 AM
xperu   Call George Hussey at AA he helped through my FI p...   Mar 21 2007, 11:54 AM
Joe Sharp   Look. I've had a lot of luck with carb convers...   Mar 21 2007, 11:58 AM
rhodyguy   that's a nice link rich. not to hj, i've t...   Mar 21 2007, 11:59 AM
andys   I had a new '73 2.0 that after a few years lef...   Mar 21 2007, 01:15 PM
djfamousa   Thank You everyone for all your help. This is by ...   Mar 21 2007, 01:59 PM
horizontally-opposed   Thank You everyone for all your help. This is by...   Mar 21 2007, 02:48 PM
r_towle   I would say....and I am not a carb hater, if you p...   Mar 21 2007, 02:59 PM
horizontally-opposed   I would say....and I am not a carb hater, if you ...   Mar 21 2007, 04:36 PM
- Lo-Fi Version Time is now: 30th April 2026 - 08:12 PM
