| John |
Mar 25 2007, 12:05 AM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
My monitor has been good to me for the past 6.5 years or so since I received it as a gift.
It is/was an NEC FP1370 display (20/21" CRT display). Over the past couple months, it has sometimes emitted a high pitched squeal that seemed to go away once it warmed up 2-3 minutes after turning it on. Recently it stopped doing that and seemed to act normal. Today, it emitted an arcid odor as if an electronic component had let out the magic genie (smoke) inside. The monitor did not stop working or appear to have changed display qualities other than the left hand side top was VERY hot to the touch and smelled of the same arcid odor that the monitor had emitted. We did not notice any smoke, just the odor. It took some time maybe 5 minutes to figure out that the odor source was indeed the monitor. I unplugged the unit and am not using it as I am afraid it may cause a fire. My main questions are: 1. Should I junk the monitor or should I search out some sort of repair facility. I have done no research on this. 2. Has anyone ever had a monitor repaired? Was it worth it? 3. How much is a 20-21" LCD monitor? 4. Any guesses as to what may have burned up, yet allow the unit to continue to function? I know this was not an inexpensive monitor, and I already miss it. It was much larger than the 19" unit I am currently using. I hate to see it go, but if a replacement is to be made, I will replace it with an LCD display (less energy, less space, sharper image). I use my display for CAD and graphic applications as well as surfing the web, so I opt for the larger displays. Advice is always welcome. |
| smontanaro |
Mar 25 2007, 06:35 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
I agree with the others, replace it with an LCD. FWIW, it sounds like the flyback transformer went kerflooey. The only reason I know this is...
Back in the dark ages when I worked for GE we were using Sun 2/120 or Sun3/50 or something of similar vintage when this happened to mine. Not knowing what it was, but since we were under contract to Sun I called the local Sun office. They weren't in yet, so their answering service picked up the call (remember answering services?) I left a message that "my Sun died". About freaked the lady out because she thought I said "my son died"... Skip |
John OT: Monitor Death Mar 25 2007, 12:05 AM
bd1308 Go to a shop ask what they want for repair
if rep... Mar 25 2007, 12:40 AM
kpex914 I picked up a 21" widescreen LCD monitor a fe... Mar 25 2007, 01:35 AM
Rand Please don't invest money into repairing a tub... Mar 25 2007, 02:02 AM
Bartlett 914 It is possible that a cap smoked. Electrolytic cap... Mar 25 2007, 09:50 AM
swl I'll join the 'junk it' contingent. M... Mar 25 2007, 11:48 AM
Gint :agree:
Repairing a monitor is not worth the cost... Mar 25 2007, 12:24 PM
Bartlett 914 I am with it on the" trash it" crowd. Bu... Mar 25 2007, 12:57 PM
dgw Junk it.
if you are doing graphics and cad, a ... Mar 25 2007, 01:48 PM
John I'm currently using an old 19" CRT I had ... Mar 25 2007, 09:31 PM
cooltimes Junk it. I had my NEC 21" repaired and it wen... Mar 26 2007, 02:33 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:50 PM |
