> WOT: SQL query help needed again ...
post Mar 26 2007, 04:41 PM
Resident German
it's time for another SQL question ...
here's the problem:
i have a table with event log information. it has a unique id for each entry (primary key), a user id, timestamp and other info.
getting the info out of the table is easy except for one particular way.
what i need is a page where i list all the last actions taken by any user per day.
meaning, if users xyz created 30 logentries today, i only want to show the latest for any given day.
so, the list should contain exactly ONE entry for each distinct user per day, showing his/her latest action ...
something like this, except, the query below doesn't work ... (IMG:style_emoticons/default/rolleyes.gif)
CODE
SELECT * FROM tbl_EventLog WHERE iID IN (
  SELECT DISTINCT el.iUserID, dummy.iID FROM tbl_EventLog as el
  INNER JOIN tbl_EventLog as dummy ON dummy.iUserID = el.iUserID
  WHERE (el.dtCreated >= '3/26/2007 0:00:01 AM')
anyone?
(IMG:style_emoticons/default/confused24.gif) Andy
watsonrx13
post Mar 26 2007, 06:52 PM
Andy, what's the fields that you're trying to return?
If you only wanted the userid and date/time then....
Select MAX(date/time),userid
from xxxx
where date/time between fromdate and todate
group by userid;
BTW, I'm a PL/SQL Oracle developer....
-- Rob
post Mar 26 2007, 07:02 PM
Resident German
QUOTE(watsonrx13 @ Mar 26 2007, 04:52 PM) *
from xxxx
group by userid;
-- Rob
yeah, thought of that but won't work. i need all the columns in the table for each result.
the problem with "GROUP BY" as well as "DESTINCT" is that you can't have any other fields returned unless you add them to the "GROUP BY".
which renders the query useless ...
(IMG:style_emoticons/default/headbang.gif) Andy
PS: what i need:
- go through all rows in table tbl_EventLog
- find all entries from today
- narrow down to last entry for each user
- sort by time (DESC)
each user has many entries in the event log every day, but the list should only show their latest activity ...
the output will look like this (note that the list *should* be sorted by time, but it isn't right now):
SirAndy   WOT: SQL query help needed again ...   Mar 26 2007, 04:41 PM
Air_Cooled_Nut   Can you use a MAX clause on the date/time stamp? ...   Mar 26 2007, 05:14 PM
SirAndy   Can you use a MAX clause on the date/time stamp? ...   Mar 26 2007, 05:24 PM
fiid   :agree: He's right - we have to do something s...   Mar 26 2007, 05:25 PM
fiid   I think you might group by userid - but not sure.....   Mar 26 2007, 05:25 PM
blitZ   The Max(dtCreated ) would probably work, then grou...   Mar 26 2007, 05:26 PM
SirAndy   The Max(dtCreated ) would probably work, then gro...   Mar 26 2007, 06:01 PM
drewvw   Not sure what DB you are using, but any thoughts o...   Mar 26 2007, 06:10 PM
SirAndy   Not sure what DB you are using, but any thoughts ...   Mar 26 2007, 06:29 PM
drewvw   yeah, i could. MS-SQL 8 Server. problem is, the ...   Mar 26 2007, 06:42 PM
SirAndy   Do we have any true DBAs in the club or just prog...   Mar 26 2007, 06:53 PM
SirAndy   plus, i just noticed, with my hacked solution, i c...   Mar 26 2007, 06:31 PM
watsonrx13   Andy, what's the fields that you're trying...   Mar 26 2007, 06:52 PM
SirAndy   Andy, what's the fields that you're tryin...   Mar 26 2007, 07:02 PM
drewvw   I am the same way....I know enough DB/SQL to be da...   Mar 26 2007, 06:59 PM
SirAndy   well, at least i got the list ordered by time now ...   Mar 26 2007, 07:38 PM
blitZ   Hmm, wouldn't something like this work? SEL...   Mar 26 2007, 08:09 PM
SirAndy   Hmm, wouldn't something like this work? SE...   Mar 26 2007, 08:22 PM
ClayPerrine   Andy, Look up a tool on Microsoft's website c...   Mar 26 2007, 08:47 PM
SirAndy   Andy, Look up a tool on Microsoft's website ...   Mar 26 2007, 09:00 PM
ClayPerrine   Andy, Look up a tool on Microsoft's website...   Mar 26 2007, 09:46 PM
bigkensteele   I have kicked this around for a half hour, and I t...   Mar 26 2007, 10:18 PM
SirAndy   I have kicked this around for a half hour, and I ...   Mar 26 2007, 10:29 PM
drewvw   good response...avoiding IN clauses is nice becaus...   Mar 26 2007, 10:23 PM
- Lo-Fi Version Time is now: 14th August 2026 - 04:17 AM
