| SirAndy |
Mar 26 2007, 04:41 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,490 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
it's time for another SQL question ...
here's the problem: i have a table with event log information. it has a unique id for each entry (primary key), a user id, timestamp and other info. getting the info out of the table is easy except for one particular way. what i need is a page where i list all the last actions taken by any user per day. meaning, if users xyz created 30 logentries today, i only want to show the latest for any given day. so, the list should contain exactly ONE entry for each distinct user per day, showing his/her latest action ... something like this, except, the query below doesn't work ... (IMG:style_emoticons/default/rolleyes.gif) CODE SELECT * FROM tbl_EventLog WHERE iID IN ( SELECT DISTINCT el.iUserID, dummy.iID FROM tbl_EventLog as el INNER JOIN tbl_EventLog as dummy ON dummy.iUserID = el.iUserID WHERE (el.dtCreated >= '3/26/2007 0:00:01 AM') ) anyone? (IMG:style_emoticons/default/confused24.gif) Andy |
| SirAndy |
Mar 26 2007, 07:38 PM
well, at least i got the list ordered by time now ...
still not pretty, looping queries and all, but it works, i guess ... (IMG:style_emoticons/default/dry.gif) Andy CODE SELECT iUserID, max(dtCreated) as dtMax FROM tbl_EventLog GROUP BY iUserID ORDER BY dtMax DESC this gives me a initial resultset with all the user ids sorted by date. i now can loop through all of these and find the latest entries for the day ... |
| blitZ |
Mar 26 2007, 08:09 PM
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Hmm, wouldn't something like this work?
SELECT * FROM tbl_EventLog WHERE iID IN ( select iID from ( SELECT iUserID, iID, max(dtCreated) as lastEntry FROM tbl_EventLog WHERE dtCreated >= '3/26/2007 0:00:01 AM' group by iUserID, iID ) dTable ) order by dtCreated |
| SirAndy |
Mar 26 2007, 08:22 PM
Hmm, wouldn't something like this work? SELECT * FROM tbl_EventLog WHERE iID IN ( select iID from ( SELECT iUserID, iID, max(dtCreated) as lastEntry FROM tbl_EventLog WHERE dtCreated >= '3/26/2007 0:00:01 AM' group by iUserID, iID ) dTable ) order by dtCreated no suck luck ... (IMG:style_emoticons/default/sad.gif) tried it, returns the full set of 4000+ entries in the eventlog for today. keep 'em coming ... (IMG:style_emoticons/default/type.gif) Andy |
SirAndy WOT: SQL query help needed again ... Mar 26 2007, 04:41 PM
Air_Cooled_Nut Can you use a MAX clause on the date/time stamp? ... Mar 26 2007, 05:14 PM
Can you use a MAX clause on the date/time stamp? ... Mar 26 2007, 05:24 PM
fiid :agree: He's right - we have to do something s... Mar 26 2007, 05:25 PM
fiid I think you might group by userid - but not sure..... Mar 26 2007, 05:25 PM
blitZ The Max(dtCreated ) would probably work, then grou... Mar 26 2007, 05:26 PM
The Max(dtCreated ) would probably work, then gro... Mar 26 2007, 06:01 PM
drewvw Not sure what DB you are using, but any thoughts o... Mar 26 2007, 06:10 PM
Not sure what DB you are using, but any thoughts ... Mar 26 2007, 06:29 PM
drewvw
yeah, i could. MS-SQL 8 Server.
problem is, the ... Mar 26 2007, 06:42 PM
Do we have any true DBAs in the club or just prog... Mar 26 2007, 06:53 PM
SirAndy plus, i just noticed, with my hacked solution, i c... Mar 26 2007, 06:31 PM
watsonrx13 Andy, what's the fields that you're trying... Mar 26 2007, 06:52 PM
Andy, what's the fields that you're tryin... Mar 26 2007, 07:02 PM
drewvw I am the same way....I know enough DB/SQL to be da... Mar 26 2007, 06:59 PM
ClayPerrine Andy,
Look up a tool on Microsoft's website c... Mar 26 2007, 08:47 PM
Andy,
Look up a tool on Microsoft's website ... Mar 26 2007, 09:00 PM
ClayPerrine
Andy,
Look up a tool on Microsoft's website... Mar 26 2007, 09:46 PM
bigkensteele I have kicked this around for a half hour, and I t... Mar 26 2007, 10:18 PM
I have kicked this around for a half hour, and I ... Mar 26 2007, 10:29 PM
drewvw good response...avoiding IN clauses is nice becaus... Mar 26 2007, 10:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th August 2026 - 05:15 AM |
