All you Weber Pro's, A couple of questions |
Grelber |
Mar 28 2007, 03:48 PM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
When I hold the rpm steady at around 3200 or so, I get a "surge" back and forth (not a lot). Is this due to unbalanced Webers?
Also, where is the best place to get a flow meter so I can get them balanced. |
Joe Ricard |
Mar 28 2007, 04:02 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Uni-syn with a ball in tube kinda sucks but the more expesive one (name ??) with curver scale and needle is good
I set my 914 @ 3000 RPM. both carbs get synched up by adjusting rod length and it is oh soooo smooth. Then let the carbs sit on the idle stops and play with those to attain the idle speed you want keeping them even of course. If you really want to drive your self nuts turn the motor off and see if both throttle plates are fully open when stomping on the pedal. There are some linkage systems out there that are not exactly easy to make work perfectly. |
chris914 |
Mar 30 2007, 12:01 AM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
I set my 914 @ 3000 RPM. both carbs get synched up by adjusting rod length and it is oh soooo smooth. Then let the carbs sit on the idle stops and play with those to attain the idle speed you want keeping them even of course. What is your total method from start to finish? |
Lo-Fi Version | Time is now: 1st June 2024 - 12:14 AM |
