favorite engine drop method, what's yours? |
mightyohm |
Nov 21 2003, 11:02 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Last time I helped drop a 914 engine, we used the Pelican method of lowering the car almost to the ground and letting the motor plop out onto a furniture dolly. I don't know that I like this method because it really requires 2 jacks and there is no obvious way to get the engine back in when you're done, since you used gravity to help get it out.
I would like to raise and support the car, then lower the engine on my floorjack. But there is obviously going to be a balance problem. I've also heard some people use threaded rods to slowly lower everything but this sounds like too much trouble. So what's the best way? |
Brad Roberts |
Nov 21 2003, 11:49 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Oh.. I dont own a dolly.
The rear muffler hanger works great as a grab handle for balancing the engine on the floorjack (which works as the dolly) I'm lazy. I dont want to run back and forth from either side loosening the nuts on the threaded shaft a little at a time. Same cat (again and again) B |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:46 PM |
