will these calipers work on my 914? |
rfuerst911sc |
Apr 7 2007, 07:12 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have 1972 911 Boge struts on the front of my 914 and I am still trying to figure out what brakes I will use front and rear. I know many people think the 1974 and later 3.5 inch struts are better but I have these and I'm gonna use them. My question is can you run rear Carrera ( 1984-1989 ) calipers on the front? If I understand this correctly this would give me a 24mm front rotor with caliper pistons that would work well with M calipers in the rear with a adjustable proportioning valve, anyone running this setup? I am going to install a 19mm master cylinder. This will be a street/autocross machine with occasional DE's thrown in. Oh yea I'll be throwing in a 911 engine too!! Any thoughts on this brake setup?
Eric_Shea |
Apr 7 2007, 11:46 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE My plan for engine power is a 2.4,3.0 or 3.2 so horsepower will be in the 150-225 range. More... If you're in the 150 range the set-up you have should be fine with 914 rear calipers. If you go beyond that I would recommend what others have with the 3.5" struts and either A or S-Calipers. I would then look for a Ferrari caliper for the rear (needs a bleeder mod). |
Lo-Fi Version | Time is now: 10th June 2024 - 10:40 AM |
