Scott-thundercat |
Member ![]() ![]() Group: Members Posts: 159 Joined: 16-October 06 From: Reno, NV Member No.: 7,049 ![]() |
so today i'm going up a hill and a ton of oil smoke starts coming out the back. i thought it was one of my pushrod tubes whos leak i've been fighting for a while now. stop after i get off the freeway- look under see a ton of oil just dripping off the heat exchanger. drive a little further and stop at a gas station after blowing a bunch of oil smoke. buy some oil- check again to see where leak is coming from- hmmmm valve cover doesnt look right.... hmmm- WTF the bailing wire is not holding it on! the bailing wire slipped off the valve cover somehow and is rotated to the bottom of it's arc. the valve cover is free floating and all that was holding it on was the silicon on the gasket at the top- just freely flowing oil out the bottom where it was loose! put the bailing wire back on and now just have to worry about all that oil slowly cooking off. any suggestions on removing the oil residue?
really wierd stuff. |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
Might have been because it was cocked, but when you let off the gas, especially going down a long grade, the engine makes so much vacuum that it can pull the gasket out from under the valve cover. Make sure your breather is all clean and glue the gaskets into the cover, like John suggested. Just glue on the valve cover side, it's easier to clean than the heads.
Lo-Fi Version | Time is now: 11th July 2025 - 09:10 AM |
