| obscurity |
Apr 8 2007, 07:46 PM
Member ![]() ![]() Group: Members Posts: 412 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
I did a search but didn't find much. What gas are you using for your MIG welder? 100% CO2, CO2/argon, or 100% Argon?
Just Curious, John W. |
| John |
Apr 8 2007, 09:22 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I did a search but didn't find much. What gas are you using for your MIG welder? 100% CO2, CO2/argon, or 100% Argon? Just Curious, John W. For steel, I prefer the 75/25 ARGON/CO2 mix. You can go CO2, but your welds may not be as clean looking. I feel that the Argon helps with less than ideal welding conditions. For Aluminum TIG, I think our shop uses Helium. just my $0.02 |
obscurity MIG welding gas Apr 8 2007, 07:46 PM
skline You could either have Aaron come over and fart aro... Apr 8 2007, 07:49 PM
JPB When all else fails or when in dought, us straight... Apr 8 2007, 07:50 PM
PRS914-6
I did a search but didn't find much. What ga... Apr 8 2007, 07:55 PM
Aaron Cox 50/50 fart / argon mix as skline mentioned :roll... Apr 8 2007, 07:58 PM
LS6/914 Mild steel, 75% Argon / 25% CO2. Aluminum, 100% Ar... Apr 8 2007, 08:27 PM
BigD9146gt FWIW, the gas mix Argon and CO2 reasoning is 75%/2... Apr 8 2007, 09:03 PM
nebreitling if you're cheap, use straight CO2. it costs n... Apr 8 2007, 09:14 PM
Travis Neff 75/25 Argon/CO2 Mix Apr 8 2007, 09:37 PM
Andyrew helistar I do believe its called.. but its 75/25.. Apr 8 2007, 09:59 PM
Maltese Falcon 75/25 aka "Steel Mix"
marty Apr 8 2007, 10:33 PM
bperry I use 100% CO2 but then I only weld steel and my w... Apr 8 2007, 10:50 PM
LvSteveH Good advice so far. A few other points of interest... Apr 9 2007, 02:02 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:59 PM |
