Head Scratcher...Only 2 Injectors Firing, 74 2.0 (D-Jet) |
BMartin914 |
Apr 12 2007, 07:29 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
I have a 74 2.0 w/ d-jet that is only firing 2 of the 4 injectors.
I have already: -swapped connectors on each side, problem moves with connectors -swapped trigger points, problem remains unchanged -checked continuity throughout system (injectors, trigger points, etc.) -case ground terminals brand new, female ground connectors have been cleaned Any suggestions (ideas) as to what may be causing this condition? I feel like I have been through most if not all of the appropriate troubleshooting procedures and still can't seem to put my finger on the problem. I have got to be missing something small... |
jasons |
Apr 13 2007, 08:32 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
If its the diagonal pairs, its got to be your trigger points. The contacts may look good, but the little dudes that ride on the dizzy shaft wear out. When they wear out, the contacts don't open and close.
Lo-Fi Version | Time is now: 10th June 2024 - 01:35 PM |
