Head Scratcher...Only 2 Injectors Firing, 74 2.0 (D-Jet) |
BMartin914 |
Apr 12 2007, 07:29 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
I have a 74 2.0 w/ d-jet that is only firing 2 of the 4 injectors.
I have already: -swapped connectors on each side, problem moves with connectors -swapped trigger points, problem remains unchanged -checked continuity throughout system (injectors, trigger points, etc.) -case ground terminals brand new, female ground connectors have been cleaned Any suggestions (ideas) as to what may be causing this condition? I feel like I have been through most if not all of the appropriate troubleshooting procedures and still can't seem to put my finger on the problem. I have got to be missing something small... |
pbanders |
Apr 13 2007, 01:56 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
If you've swapped in known good trigger points, and checked the injectors and harness by measuring the resistance to ground of each injector at the ECU plug, then your ECU is bad. There are two output driver circuits in the ECU that each drive two injectors, most likely, one of yours is dead, probably one or both of the two Ge power transistors is out.
Oh, just thought of one more possibility - check you trigger contact point circuit at the ECU plug. You might have a wiring fault to the TC's. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:21 AM |
