Stripped for paint |
watsonrx13 |
Apr 14 2007, 08:34 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well, I finally finished prepping the car for paint. I have a local painter that has agreed to paint my car, so to save money he requested that I strip the paint down to metal. He'll do the minor body work, primer, base-coat, clear-coat. I'm suppose to take it by tomorrow (Sunday), but I'll have wait until the front passes by.
It taken me about 40 hrs to remove all of the paint. I started after work last Thursday, all day Friday (Good friday holiday), Saturday, Sunday and today. This is the only body repair needed. It had about 1/2" of bondo at the deepest. It took me 5 hrs to strip this door. There's also some body work to be done on the rear quarter panel. After stripping I used Ospho to protect the metal, then painted a light coat of etch primer, per the painter's requirements... Here's why it's taken me so long to strip the car, I didn't have a large enough air tank to run the DA, so I strip everything with this electric hand drill with 3M purple sanding discs. For the next teener to be painted, I'm going to buy an electric DA sander.... Here's an in process shot... After spending 10 hrs today finishing the stripping I forgot to take any pictures of the completely naked teener.... I'll take pics before I drop it off at the painters.... BTW, I'm enjoying several nice Black-n-Tan beers today and tomorrow and looking forward to doing NO WORK on the teener tomorrow... -- Rob |
Chuck |
Apr 15 2007, 12:13 PM
What it eventually will look like . . . . Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
Just curious (as I will need to strip my own project here in short order) why you chose to sand the paint off versus using a chemical stripper like aircraft stripper? My plan was to use aircraft stripper.
watsonrx13 |
Apr 15 2007, 03:49 PM
Just curious (as I will need to strip my own project here in short order) why you chose to sand the paint off versus using a chemical stripper like aircraft stripper? My plan was to use aircraft stripper. Chuck, I actually tried both. Prior to sanding a panel, I laid down a 2 square foot section using the aircraft stripper. I then went back to sanding. I'd take a break from the sanding and scrape the aircraft stripper off. I found that it would take 3 tries to get the paint off with the stripper. With the sanding, once I hit, it went down to bare metal. I used the stripper in the corners where the sanding disc wouldn't reach. You should experiment with which ever process works for you. Either way I'm exhausted and won't do another paint stripping for at least a month... (IMG:style_emoticons/default/biggrin.gif) -- Rob |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:34 AM |
